- Thank you received: 2
Carbs
- Hoopdee
78 kz 650.....
Gsxr front and rear suspension
Stage 3 jets
Pods
Custom exhaust
Dynatec ign
- Thank you received: 2755
- Hoopdee
78 kz 650.....
Stage 3 jets
Pods
Custom exhaust
Dynatec ign
- Hoopdee
78 kz 650.....
Stage 3 jets
Pods
Custom exhaust
Dynatec ign
- Thank you received: 2829
swest wrote: Do you have a manual, you'll need one.
+1 !!! Ed
- Hoopdee
78 kz 650.....
Stage 3 jets
Pods
Custom exhaust
Dynatec ign
Exactly which spark plugs are in the engine?
- Hoopdee
78 kz 650.....
Stage 3 jets
Pods
Custom exhaust
Dynatec ign
You can check the petcock a couple ways. Disconnect the vacuum line from the #2 carb. It should be dry - no fuel in it. If any fuel is present in the tube there's a petcock problem. Another way is to disconnect the vacuum line and cap off the vacuum nipple on the carb and the vacuum line on the petcock. Install a fresh spark plug in #2 cylinder, turn the petcock to Prime, and take a ride. If after riding a while the #2 spark plug is not wet the petcock diaphragm has a problem. If new plug in cylinder #2 is wet with the vacuum line disconnected the problem is probably in the carb. Ed
