1980 KZ440A LTD intake issue
- jimmyboy92
20 Sep 2016 16:34 #743022
by jimmyboy92
1980 KZ440A LTD intake issue was created by jimmyboy92
Hey there!
So I have a 1980 KZ440A LTD that has been professionally gone through, carbs are spotless, new carb boots, clean gas, stock jets, etc. The problem is that it won't run with the air box connected. Take off the air box and it runs fine. What I can't understand is that everyone says these bikes run like s**t without the stock air box/filter, yet mine only runs without it and everything else on the bike is stock. Help!
And thank you
And thank you
- Nebr_Rex
- Thank you received: 300
20 Sep 2016 19:23 #743039
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic 1980 KZ440A LTD intake issue
If the carbs are not choked the jetting is not stock.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Kray-Z
- I need more power Scotty....
- Thank you received: 107
20 Sep 2016 19:53 #743043
by Kray-Z
Replied by Kray-Z on topic 1980 KZ440A LTD intake issue
Hmmm - how is it with the air box in but the filter element out?
What exactly do you mean by "won't run"????? Does it still start? Idle? Rev up?
This is sounding like the air box wasn't installed properly or the filter is clogged or incorrect. On most Japanese bikes with CV carbs, stock / original carb set up (not only jetting, but the entire tune of the carbs) normally will start and idle (ish), but won't perform well under load or at higher engine speeds without the stock intake plumbing in place and operating properly....just my experience.
Conversely, some simpler low performance engines with slide carbs can function o.k. (ish) without the air box or any filter in place....
- jimmyboy92
21 Sep 2016 06:24 #743069
by jimmyboy92
Replied by jimmyboy92 on topic 1980 KZ440A LTD intake issue
Runs excellent until you put the air box together then runs like crap and dies out when trying to rev it.
As soon as you put anything in front of it (the air box) I have tried with filter with out filter and it just starves for air.
- Thank you received: 2829
21 Sep 2016 06:28 - 21 Sep 2016 06:28 #743071
by 650ed
Agree 100%. If the engine runs well with no air filtration whoever when through the carbs missed something if they believe them to be clean, set correctly, and have stock jetting. Time to take another look. Ed
Replied by 650ed on topic 1980 KZ440A LTD intake issue
Nebr_Rex wrote: If the carbs are not choked the jetting is not stock.
Last edit: 21 Sep 2016 06:28 by 650ed.
- jimmyboy92
22 Sep 2016 18:13 #743241
by jimmyboy92
Okay so update.
My mechanic went through the bike again and ended up calling customer support at keihen and gave a few suggestions. After making a few small adjustments and putting the bike back together, she purrs like a kitten. Not sure what it was, but most likely a few little things compounding into a bigger issue.
Thanks for everyone's input!
