New ready available kz750 keihin rebuild kits
  • undiablo
  • undiablo's Avatar Topic Author
14 Sep 2016 08:48 - 14 Sep 2016 12:50
#742203
It is the first time I find a complete full rebuild kit for Keihin CV34 carbs of kz750.
The price is awesome!
Attachment Screenshot_20160914-124631.JPG not found
Vs "economy" USD20.- rebuild kit from K&L:
Attachment s-l225.jpg not found
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
Last edit: 14 Sep 2016 12:50 by undiablo.
The following user(s) said Thank You: JR
  • mopguy
  • mopguy's Avatar
Re: New ready available kz750 keihin rebuild kits
14 Sep 2016 11:08
#742210
Where?
  • Nessism
  • Nessism's Avatar
14 Sep 2016 12:44
#742218
I'm curious as well. I've rebuilt several sets of those carbs and it's not an easy process. You have to pull the choke butterfly shafts out of the carbs to be able to ungang them and perform a proper dip job to clean the passages. A kit including the float bowl O-rings, float needles, and O-rings for the interconnect tubes, pilot screws, and pilot plugs would be awesome. Sadly, most rebuild kits I've seen provide needless, and often inferior parts, such as jets. I'm much rather just clean the original Keihin parts where ever possible and not replace them.
  • undiablo
14 Sep 2016 12:51
#742220
Sorry, I have inserted the pictures now. Pls check if you can see them.
  • Nessism
  • Nessism's Avatar
14 Sep 2016 13:09
#742224
I don't know man. So again, I'd rather reuse the real Keihin brass parts.
A couple of the parts I don't recognize either: what is the part just below the float needle, and the long part the float needle is sort of pointing at?
The kit is missing the fuel transfer tube O-rings too. Those are the ones that are typically the most degraded too.
  • undiablo
14 Sep 2016 13:25
#742236
Nessism wrote: what is the part just below the float needle, and the long part the float needle is sort of pointing at?
The part below the float needle is the NEEDLE JET, it works together with you JET NEEDLE.
The float needle is pointing to the MAIN NOZZLE, wich works under the PRIMARY MAIN JET #62.
  • Nessism
  • Nessism's Avatar
14 Sep 2016 13:36
#742241
I'm a little embarrassed. On the sets I've done I didn't remove the MAIN NOZZLE or the NEEDLE JET. I soaked the carb bodies in carb dip with those parts still installed. Do they slide in and out of the carb body easily?
  • undiablo
14 Sep 2016 15:02
#742250
The MAIN NOZZLE is held at place by the PRIMARY MAIN JET,
The same with the NEEDLE JET. It is held at place by the NEEDLE JET HOLDER,
PRIMARY MAIN JET and NEEDLE JET HOLDER both are threaded.
MAIN NOZZLE and NEEDLE JET are threadless. The slide through the aluminum holes.
  • 750 R1
  • 750 R1's Avatar
14 Sep 2016 15:59
#742259
I can't comment on the quality of these carb kits but for anyone interested, cruzin image is a Japanese company, here's a link to them directly, they have plenty of other parts including piston kits... ;)
cruzinimage.jugemcart.com/?pid=1569290
  • dvnsta
  • dvnsta's Avatar
15 Oct 2016 17:10
#745291
Know this is an older thread. I checked out this link and sadlu does not seem to be available any longer. They have 83-85 was hoping this kit was still.any other place a kit like this can be found.
1982 KZ 750 LTD H3 stock except with custom seat skin and kawasaki period backrest.
Kawasaki 1989 eliminator 250 b3
  • Nessism
  • Nessism's Avatar
15 Oct 2016 17:22
#745292
dvnsta wrote: Know this is an older thread. I checked out this link and sadlu does not seem to be available any longer. They have 83-85 was hoping this kit was still.any other place a kit like this can be found.
Searched "KZ750 carb kit" and this came up at the top...
  • dvnsta
  • dvnsta's Avatar
15 Oct 2016 17:31
#745293
Thanks guess its all in the wording of the search.
