Kz550
- greene.1993
11 Sep 2016 06:09 - 11 Sep 2016 06:12 #741826
by greene.1993
Kz550 was created by greene.1993
So I got this 82 kz550 ltd. It came straight piped 4 into 2 exhaust and has pod filters, I've seen others like this that well go faster then mine. So I looked at the carbs it had 92 main jets in it which I believe are stock with stock needles. I put a stage 3 carb kit in it and put the 98 main jets in and put the new needles in the 4th slot from the top from what I read on forums on here that's what everyone does. Tighten up all the rubber boots and check for leaks with carb clean and there was none. Went for a ride on the highway and I could only get up to 65 mph with out the motor sputtering and having no power to go faster. I'm at a dead end here please help
Last edit: 11 Sep 2016 06:12 by greene.1993.
- Thank you received: 1656
11 Sep 2016 06:40 - 11 Sep 2016 06:57 #741832
by martin_csr
Replied by martin_csr on topic Kz550
Does your bike have TK22 carburetors? loudhvx has a motorcycle stuff page with extensive info about them & there may be jetting/tuning info for individual pod filters & muffler changes.
loudhvx --- signature links
Battery. Make certain the battery is good & fully charged by testing it with a digital multimeter. Also, you may need to check the ignition coils & spark plug wires. as the coils heat up, internal shorts & poor connections can cause performance issues.
Last edit: 11 Sep 2016 06:57 by martin_csr.
