Help with carb identification
  • Sidewaze
  • Sidewaze's Avatar Topic Author
02 Sep 2016 10:53 - 02 Sep 2016 11:08
#740922
I have search and read a few posts but can't seem to verify what carb I have on my 1978 KZ1000 A2A. Without removing I can't see and numbers. My petcock has res-pri-on, no off position. Any help would be appreciated.
Thanks,
Scott
Last edit: 02 Sep 2016 11:08 by Sidewaze.
Re: Help with carb identification
02 Sep 2016 11:06
#740924
Sidewaze wrote: I have search and read a few posts but can't seem to verify what carb I have on my 1978 KZ1000 A2A. Without removing I can't see and numbers. My petcock has res-pri-on, no on position. Any help would be appreciated.
Thanks,
Scott
no on position -- suspecting this was intended to say "no off position."
Stock carbs are Mikuni VM26SS, which are sometimes referred to as 26mm manual slide.
The stock 26mm manual slide Mikuni would probably have either a side-located pilot circuit air adjustment screw or a pilot circuit mixture adjustment screw located on the underside of the carb closest to the engine.
Good Fortune! :)
