- Thank you received: 15
29mm smoothbore pilot size 17.5 20 25 ???
- richard
29 Aug 2016 19:53 #740453
by richard
29mm smoothbore pilot size 17.5 20 25 ??? was created by richard
Have 78 kz1000
They say there are 3 pilot sizes for the kz1000
When using the 29s. The last pilot size is 25 then it says for the later version?
If they are referring to the 29s how can I tell the difference between the 29 carbs
Or are they referring to later kz like the j or gpz?
- baldy110
- Thank you received: 512
31 Aug 2016 09:54 - 31 Aug 2016 09:55 #740653
by baldy110
Replied by baldy110 on topic 29mm smoothbore pilot size 17.5 20 25 ???
Use the 17.5 pilots you won't need any larger unless you have a seriously modded engine.
Last edit: 31 Aug 2016 09:55 by baldy110.
