KZ440 no start, no matter what
  • Hexadecimus
  • Hexadecimus's Avatar Topic Author
Re: KZ440 no start, no matter what
07 Aug 2016 20:57
#737778
Nebr_Rex wrote: Compression , fuel, spark which one are you missing?
150/143 psi, bright blue, and enough to get the plugs wet if I keep cranking. That's why I asked about checking the cam timing in the first post. Any way to verify that it hasn't jumped without pulling the big valve cover?
Thanks to everyone for the replies btw. I really need this thing running.
  • Nebr_Rex
  • Nebr_Rex's Avatar
08 Aug 2016 05:09
#737801
Go ahead and pull the rocker box to check cam timing.
Just a bunch of bolts. Remove and reinstall, it will not change
anything on the engine.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Nebr_Rex
  • Nebr_Rex's Avatar
08 Aug 2016 05:15
#737802
Hexadecimus wrote: lack of ignition.
bingo
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • Hexadecimus
08 Aug 2016 08:17
#737836
bingo
I don't mean spark, btw. I already know it isn't igniting even with a strong blue spark, but the question is why. I haven't seen an engine so far off timing that it wouldn't fire, but I'll open the cam cover today. I'm out of other things to try.
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Aug 2016 08:46
#737841
Old plugs can spark out of the engine, under load they won't. As I said before, try new plugs.
  • Hexadecimus
08 Aug 2016 09:44 - 08 Aug 2016 09:45
#737846
swest wrote: Old plugs can spark out of the engine, under load they won't. As I said before, try new plugs.
I did. That's why I have 3 sets of plugs for these bikes instead of 2 now, and what's why I tested them in the 400 just to triple check. All 3 sets run great in the kz400.
Cam and sprocket mark at TDC attached. Looks good to me.
Last edit: 08 Aug 2016 09:45 by Hexadecimus.
08 Aug 2016 10:47
#737849
Hexadecimus wrote: Cam and sprocket mark at TDC attached. Looks good to me.
To me it looks like the cam is installed 180 degrees out. Take a look at the 1st image below. It shows how the cam should be installed. Then look at the 2nd image below that shows your cam. Is yours installed with the timing arrow facing the rear instead of front when the crankshaft is at TDC? Ed
Attachment 00003b-2-3-4-5-6-7-8-9-10-11-12-13-14-15-16-17-18-19-20-21-22-23-24-25-26-27-28-29-30.jpg not found
Attachment 00003a-2-3-4-5-6-7-8-9-10-11-12-13-14-15-16-17-18-19-20-21-22-23-24-25-26-27-28-29-30-31-32-33-34-35-36-37-38-39-40-41-42-43-44-45-46-47-48-49-50-51-52-53-54-55-56.jpg not found
  • Hexadecimus
08 Aug 2016 11:03 - 08 Aug 2016 11:42
#737852
Ed, the cam being 180° out, that's not really a possibility if you think about it. The crank is at TDC and the cam rotates twice per cam revolution, and the cam only determines whether that's at the beginning of the power or intake stroke. If you rotate the crankshaft one revolution the the T mark again, the camshaft will rotate 180° from where it previously was...
As far as the sprocket itself, from what I've read, it's impossible to misalign because the bolt holes are not mirrored exactly so they only align one way.
Last edit: 08 Aug 2016 11:42 by Hexadecimus.
  • Nebr_Rex
  • Nebr_Rex's Avatar
08 Aug 2016 19:47
#737938
Hexadecimus wrote: Ed, the cam being 180° out, that's not really a possibility if you think about it. The crank is at TDC and the cam rotates twice per cam revolution, and the cam only determines whether that's at the beginning of the power or intake stroke. If you rotate the crankshaft one revolution the the T mark again, the camshaft will rotate 180° from where it previously was...
You are correct.
If the timing mark is on the 'T' on the ignition advancer you are at TDC on number 2 cylinder.
If the engine does not fire on either you have no spark caused by something not letting those itty-bitty electrons
flow thru them wires.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • Armaundk
  • Armaundk's Avatar
Re: Re:KZ440 no start, no matter what
09 Aug 2016 19:15
#738052
Did you by chance remove the mechanical advancer unit? It's possible you put it back on 180 degrees off, if you did. Happens on the 750 twins often. I ditched my points and went to and electronic ignition.
If you haven't removed the advancer, I'd recommend taking it off, cleaning and greasing it and making sure it moves freely before reinstalling.
Sent from my iPad using Tapatalk
  • Hexadecimus
09 Aug 2016 20:04
#738067
Nebr_Rex wrote: You are correct.
I triple checked that it has a good spark.
Armaundk wrote: Did you by chance remove the mechanical advancer unit? It's possible you put it back on 180 degrees off, if you did. Happens on the 750 twins often. I ditched my points and went to and electronic ignition.
It wasn't off since the bike last ran. I did remove and clean it, and it seems fine. The springs return correctly. And there's only one way for the points style advancer to slide on. I wish I had the electronic like my previous Kz440 since I already have the igniter box, but I haven't found the advanced/cam assembly reasonbly priced.
I still wonder if it isn't in the carbs somewhere. I think it's receiving too much fuel rather than just being flooded from not igniting. Everything looks clean, jets appear to be stock, fuel levels are at +3 to 5 mm, and float valves are sealing. Eberyone who has looked at it is stumped though. If I can find something small enough, I'll try to gauge the jets to see if they've been drilled. Still seems like it should start though...
  • Hexadecimus
09 Aug 2016 20:06
#738069
Nearly blocking off the intake entirely introduced enough drag to keep the starter from kicking back like in that video. Seems like way more restriction than the stock air box can provide though.
