83 550 carb questions
- cruspeed
02 Aug 2016 04:11 #737044
by cruspeed
78 KZ1000 project X 2
83 550 carb questions was created by cruspeed
Literally picked up a 83 550 out of a barn a few months back. Wouldn't run for long, obvious issues once I got a good look. First pic, the small tube circled of the vacuum line to the fuel petcock? Second pic, the nipples are on a cross pipe between carbs. Should they be plugged or open?
Thanks for the help, trying to get an idle before I spend a lot of time on it.
- Thank you received: 1656
02 Aug 2016 06:30 - 02 Aug 2016 06:33 #737056
by martin_csr
Replied by martin_csr on topic 83 550 carb questions
Sometimes a closeup can be too close.
The 1st pic is probably the petcock vac line & the 2nd one is a vent. there should be two vents. open to atmosphere & directed downward to keep water out.
Here's a topic by loudhvx with links to his motorcycle stuff pages. one of them is for the 550 TK22 carburetors.
Last edit: 02 Aug 2016 06:33 by martin_csr.
The following user(s) said Thank You: cruspeed
- cruspeed
02 Aug 2016 06:45 #737059
by cruspeed
Replied by cruspeed on topic 83 550 carb questions
Perfect, thanks for the link. Here's an image I pulled from louds site. I had to crop the image since I couldn't upload a large file off my phone.
gpzweb.s3-website-us-east-1.amazonaws.co...Page/TK22hornEnd.jpg
