need guidance on jetting
- lobe kz650 81
28 Jul 2016 04:07 #736458
by lobe kz650 81
need guidance on jetting was created by lobe kz650 81
Hi everyone. Im new here and new to bike also. Baught a beat up 81 kz650 and it need some loving. Here is my problem: straight pipe and air pods! I figure out i need jetting...but how big? All 3 jet ? Main big and small? Pilot? Im in the dark here so if someone could educate me please
Good day to all of you
- 650mod
- Thank you received: 48
28 Jul 2016 05:24 #736461
by 650mod
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
Replied by 650mod on topic need guidance on jetting
To start- what carbs do you have on it? Vm mechanical or cv vacuum?
78 kz 650 custom
- Atlamillias
01 Aug 2016 07:49 #736943
by Atlamillias
Replied by Atlamillias on topic need guidance on jetting
I'm pretty new myself, but here's what i would say based on what I've learned.
First off, what carbs do you have? If you have the service manual for your bike (you can usually find it online) it will usually tell you what carbs it has. Also, if you disassemble your carbs, there is actually the size of the jets "imprinted" on them. If you are adding pods, there's a good chance you'll need to increase the main jet by at least 1 size.
- lobe kz650 81
03 Aug 2016 16:50 - 03 Aug 2016 16:51 #737306
by lobe kz650 81
Replied by lobe kz650 81 on topic need guidance on jetting
Sorry for the delay. I was away.
Here what i figured out so far.
Was running on 3 so i change the plugs and used 120 ml of seafoam to degonk the sleeping cylinder thinking of a quick fix( i know im lazy...but my knowledge are limited here). It work like a rocket for a whole gas tank then something happened. It started but when i gave gas it stall...once. twice. Three time then never started again. ???!!!??? Somebody got a clue for me?
Jetting part is main: 102.5 and pilote are 15
Mikuni vm24
I know i have to go bigger...but how big?
Mikuni vm24
Last edit: 03 Aug 2016 16:51 by lobe kz650 81.
- 650mod
04 Aug 2016 18:34 #737462
by 650mod
78 kz 650 custom
Check out my project post, all my carb info is there. My 650 is bored out to a 720, has a 4-1 exhaust, pod filters, and stage 3 dyna jet kit. Main jet is the largest in the kit- 122.5 I think. Needle is on the 3rd clip from bottom I believe. Pilots are 17.5, turned out 2-2.25 turns. This could be a rough start for you. If it stalled like that, chances are it's not fueling enough on the pilot circuit, so upping to a 17.5 would be a good start.
Also- if you want the bike to run properly with pods- invest in a ColourTune unit to tune the pilot circuit dead on, and a vacuum tool to synch the carbs up. You'll chase your tail forever if you don't have the proper tools with pods. Trust me, I did.
78 kz 650 custom
The following user(s) said Thank You: lobe kz650 81
