- Thank you received: 3
KZ440 Carburetor Leaking Gas from Main Jet
- BornAgainBiker
25 Jul 2016 13:25 #736191
by BornAgainBiker
All the best, Jeff
1984 KZ440 D6
KZ440 Carburetor Leaking Gas from Main Jet was created by BornAgainBiker
Hi All,
My KZ440 has been missing on the right cylinder and fouling the plug on that side, so I was observing the carburetors while it was running and noticed that the right carb had gas bubbling out around the main jet at anything above idle. After a second or two of this, the right cylinder would miss badly and spit back through the carb. The float levels are within spec and the carbs have been cleaned multiple times. Does anyone know what the likely causes of this are?
All the best, Jeff
1984 KZ440 D6
- MadShad
- Thank you received: 8
25 Jul 2016 14:35 #736199
by MadShad
Shelbyville, Indiana. '80 KZ1000
No more of that talk or I'll put the leeches on you, understand?
Replied by MadShad on topic KZ440 Carburetor Leaking Gas from Main Jet
Make sure the bowl vent isn't clogged, I'd take another look at the fuel level and needle seat.
The following user(s) said Thank You: BornAgainBiker
