Kz750 Spectre throttle problem
- zdc28
09 Jul 2016 20:19 #734403
by zdc28
Kz750 Spectre throttle problem was created by zdc28
Hi guys, so I bought a 1983 kz750 spectre couple weeks ago and iv ran into a problem that I can't seem to figure out. I just cleaned the carbs and cleaned the gas tank and got it started but everytime I rev it past 3000rpm it revs itself up to 5000rpm and stays there after the throttle is let go. No idea why.
Here's a link to a video I posted on YouTube about the problem
Any information would be much appreciated! Thanks,
- Thank you received: 2755
09 Jul 2016 20:28 #734405
by SWest
Replied by SWest on topic Kz750 Spectre throttle problem
Vacuum leak or stuck slide/slides.
The following user(s) said Thank You: zdc28
- Thank you received: 2840
09 Jul 2016 20:57 #734409
by Nessism
Replied by Nessism on topic Kz750 Spectre throttle problem
Vacuum leak or the throttle cable is sticking. You may want to change the rubber carb runner boots that attach to the head and make sure your airbox is sealed well and the filter is in place and sealing as well. These bikes don't like any monkey business going on where the carbs can suck false air.
- JoHNY
- Thank you received: 6
10 Jul 2016 02:22 #734418
by JoHNY
+1
Kawasaki Z750P7 Spectre, Triumph Daytona 955i, Honda CBR1000FN
Replied by JoHNY on topic Kz750 Spectre throttle problem
swest wrote: Vacuum leak or stuck slide/slides.
- zdc28
10 Jul 2016 08:54 #734444
by zdc28
Replied by zdc28 on topic Kz750 Spectre throttle problem
Wow thanks for all the quick reply! I will have to look into these options.
