Rubber boot thing? KZ440 btwn engine and carb
  • Wepeel007
  • Wepeel007's Avatar Topic Author
08 Jul 2006 17:30
#60297
Hi, first post ever!
Anyways, I have a 81 KZ440 and the rubber things that hold the carbs to the engine that is screwed in with two screws are both cracked and causing my bike to run really poorly. What are these parts called? Second, where can I get them? Does anyone have any that aren't cracked?
Thank you!
Tim
Post edited by: Wepeel007, at: 2006/07/08 20:31
  • wireman
  • wireman's Avatar
Re: Rubber boot thing? KZ440 btwn engine and carb
08 Jul 2006 17:35
#60299
carb boots.anything rubber is gonna get old and dryrot over time.try z1 enterprises or someone in the links section.;)
  • trippivot
  • trippivot's Avatar
09 Jul 2006 07:56
#60438
carb insulators are available at K&L supply good quality aftermarket. there all sorts of nifty things available there all motorcycle tools and o rings insulators etc...
  • WharfRat
  • WharfRat's Avatar
09 Jul 2006 08:26
#60452
I got mine for a 79 400 right from the local Kaw dealer for $17 each.
Kenosha,WI
1979 KZ 400B2
1979 KZ 650 B3
  • Wepeel007
09 Jul 2006 17:19
#60564
Thanks guys,
also if these are both cracked could this be why my kawa is cutting out just past idle and will only run with choke on?
Tim
Post edited by: Wepeel007, at: 2006/07/09 20:20
  • wireman
  • wireman's Avatar
09 Jul 2006 20:38
#60623
i would think if boots are cracked really bad you would have a vacuam leak and leaving choke on is smoothing it out a little with extra fuel.;)
  • JMKZHI
  • JMKZHI's Avatar
Re: .
10 Jul 2006 08:00 - 03 Dec 2008 18:53
#60717
del
Last edit: 03 Dec 2008 18:53 by JMKZHI.
  • Wepeel007
10 Jul 2006 08:33
#60725
Thanks a lot guys!
