PSA cheap ($40) KZ750 E/H petcock replacement
- akolleth
17 Jun 2016 06:28 - 17 Jun 2016 06:32
No eBay APP ID and/or Cert ID defined in Kunena configurationAfter having unsuccessfully tried to rebuild my petcock on my 82 KZ750H I went searching for solutions. The bolt hole spacing is 44mm, and thankfully there is a cheap, brand new, vacuum style petcock with same spacing available. Just look for one from a GS750 replacing parts 44300-45471, and 44300-45470 the one I got said it fit the following models
•gs1150 all models...........1984-87
•gs1100e/es......................1982-83
•gs750e/ed/ez/ex/t............1981-83
•gs450tz/txz/ed..................1982-83
It bolted right on to the KZ750H and was almost the same size, so no issues with clearance. The exit tube is pointed rearward just like the original KZ petcock and it is vacuum operated, just like the original. And its all new, so no 40 year old rubber to contend with. Not bad in my book for $40.
This is the one I got (not affiliated with the seller in any way)
The light that burns twice as bright, burns half as long. And you have burned so very, very brightly Roy.
Last edit: 17 Jun 2016 06:32 by akolleth.
The following user(s) said Thank You: Nebr_Rex, JR
