GPZ 1100 Tps
- pjluckai
GPZ 1100 Tps
13 Jun 2016 10:31
Once again i post with a,call for help. I have an 82 GPZ 1100 that s been sitting for who knows how long. in efforts to restore her to former glory I've done the following:
- ultrasonic clean and test injectors
- TPS adjustment
- Replace cracked pressured fuel lines
- spark plugs
- air filter, oil change, filter, etc
However, when dialing in the tps, i can't seem to find the sweet spot. no matter which way i adjust it, i get a lurching or sputtering upon acceleration. this wasn't the case prior to the above work, but have no idea why any of the above would cause it. i took a look at the plugs after about 20 kms and they are black.... not sure what to troubleshoot next. is this just a matter of tps adjustment & more patience?
... adjustable fuel pressure regulator, pod filters, ignition coils & wires in the mail.... will start a build thread once i get started swapping gsxr components!
- TPS adjustment
- spark plugs
Pete
'82 GPZ 1100
'82 GPZ 1100
- DFIGPZ
- pjluckai
Re: GPZ 1100 Tps
13 Jun 2016 18:42DFIGPZ wrote: clean check valve in tank ?
Everything was fine before, so I just assumed it was fine. What is the easiest way to check it?
Also, any idea what this other business is beside the check valve?
Pete
'82 GPZ 1100
'82 GPZ 1100
- pjluckai
Re: GPZ 1100 Tps
15 Jun 2016 05:47 - 15 Jun 2016 05:51
To update, I only notice the sputtering once the bike is good and warm. This tells me its running too rich?...
Does anyone have any insight?
Thanks
Thanks
Pete
'82 GPZ 1100
'82 GPZ 1100
Last edit: 15 Jun 2016 05:51 by pjluckai.
- pjluckai
Re: GPZ 1100 Tps
19 Jun 2016 17:23 - 19 Jun 2016 17:24
.... Anyone? removed check valve, and seems fine.
I've installed new coils, wires and plug caps to no avail.... Vacuum sync is next n the list. Can anyone think f anything else?
Pete
'82 GPZ 1100
'82 GPZ 1100
Last edit: 19 Jun 2016 17:24 by pjluckai.
- DFIGPZ
Re: GPZ 1100 Tps
19 Jun 2016 18:50
Valve adjustment.
Air leak at carb holders.
bad fuel pressure regulator.
Bad TPS sensor.
Bad TPS sensor.
1984 750 Turbo
- flhwesty
Re: GPZ 1100 Tps
20 Jun 2016 03:27
That bike come from Thunder Bay?
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
1981 GPz1100 KZ1100-B1
1977 KZ1000LTD
1978 Z1R
