KZ400 single carb conversion
- rockerbox
- Building a KZ400 scrambler
06 Jun 2016 13:23 - 07 Jun 2016 02:18 #730313
by rockerbox
KZ400 single carb conversion was created by rockerbox
Hi!
I'm badly looking for advice on jetting my single carb conversion.
I've got a KZ400 twin with the 11th hour 2-1 intake and a Mikuni VM34. It starts, idles and rolls of ok but not much above that. I can take it to maybe 50mph/80kmh. I would say it runs as it should up to about 1/4 of the throttle range. (I've made a tape measure and marking on the throttle grip)
Everybody talks about the pilot and main jet but there are a couple of other parts to tune on the VM carbs. Throttle slide, needle jet and needle type. Aren't those important enough?
My setup right now is
Throttle slide 3.0
Needle 6DH7 2nd position from highest
Needle jet O-4
Main 170
Pilot 17,5
Any suggestions and guidance would be greatly appreciated!
Throttle slide 3.0
Needle jet O-4
Main 170
Pilot 17,5
Last edit: 07 Jun 2016 02:18 by rockerbox.
- Mykzisbroke
- Thank you received: 1
10 Jul 2016 19:07 - 10 Jul 2016 19:09 #734521
by Mykzisbroke
Replied by Mykzisbroke on topic KZ400 single carb conversion
Did you sync the carb?..... Lol. I havnt done conversion 1 into two. Doesnt seem logically like a great idea tho because cylinder vacuum will differ therefore so will the fuel. Def need the correct jets and needles and heights tho and yea itll cost a lot of your time, just like this post im writing, time youll never get back unless you get lucky and find the right info.
Last edit: 10 Jul 2016 19:09 by Mykzisbroke. Reason: Spelling
- Nebr_Rex
- Thank you received: 300
10 Jul 2016 20:17 #734528
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic KZ400 single carb conversion
Did the people who sold you your manifold give you any guidance?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
