- Thank you received: 8
1987 ZX750 carbs on 79 KZ650?
- Spencer440
05 Jun 2016 07:31 #730156
by Spencer440
1980 KZ440-B
1979 Kawasaki KZ650-C3
1987 ZX750 carbs on 79 KZ650? was created by Spencer440
No eBay APP ID and/or Cert ID defined in Kunena configurationI was wondering if these Keihin CV34 carbs had the same spacing as the stock vm24ss carbs, on the KZ650? I can get the boots and the carbs for a good deal and I think they would be a nice upgrade. Just wanted to ask around and see if anyone else knows for sure...
1980 KZ440-B
- Thank you received: 2829
05 Jun 2016 07:50 #730159
by 650ed
Replied by 650ed on topic 1987 ZX750 carbs on 79 KZ650?
If you are considering switching to CV carbs on a KZ650 the link below is "must" reading on the subject. Pablo replaced his Mikuni VM carbs with Keihin CVK carbs and gives a VERY detailed account of the project including tons of pics. When done he was thrilled with the results. Ed
forums.kz650.info/index.php?topic=9383.0
- undiablo
- Thank you received: 64
05 Jun 2016 07:57 #730160
by undiablo
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
Replied by undiablo on topic 1987 ZX750 carbs on 79 KZ650?
You can use as direct swap:
Keihin CV34 from KZ750
Mikuni BS34 from GPZ750
Keihin CV32 from ZR750 and ZR7S (needs new carb boots and airbox mod)
- Thank you received: 2840
05 Jun 2016 09:48 #730174
by Nessism
Replied by Nessism on topic 1987 ZX750 carbs on 79 KZ650?
I think there are better carb options than those CKV's. The Keihin's from the KZ750 are a direct bolt on, and you can even fit the proper airbox too.
- baldy110
- Thank you received: 512
05 Jun 2016 13:31 #730196
by baldy110
Replied by baldy110 on topic 1987 ZX750 carbs on 79 KZ650?
And $175.00 is WAY to much for those.
