spring on jet needle??
  • steveo_4192003
  • steveo_4192003's Avatar Topic Author
  • 77kz650b-1
08 Jul 2006 13:23
#60264
should i have a sping on my jet needle?( # 47/48 below)
i dont have one on there now!
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
  • wiredgeorge
  • wiredgeorge's Avatar
Re: spring on jet needle??
10 Jul 2006 06:30
#60696
If your carbs have the small yellowish plastic washers above and below the eclip on your jet needle, you should have the spring as well. Not all slides use the plastic washers and spring method but if yours does, the jet needles will flop around more than they should and could present a dangerous situation where the throttle can stick open... make sure your throttle slide stop screw is set per factory recommendations so the jet needles don't come out of the needle jets with the throttle wide open.
  • steveo_4192003
  • 77kz650b-1
10 Jul 2006 08:34
#60726
ok, i didnt have any spring or yellow washer and i did set the throttle stop to a good height!
thanks agian WG!
ill have more ?s soon to come!!
  • steveo_4192003
  • 77kz650b-1
10 Jul 2006 10:11
#60747
thanks agian WG!
