1979 kz400 vm30
- dlc198322312
09 May 2016 14:42 #725392
by dlc198322312
1979 kz400 vm30 was created by dlc198322312
I am not sure if this has been answered but can you jet a vm30 up enough to run a 2 into 1 manifold on a kz400? My buddy has a single vm30 he is icon me for free and I wasn't sure if it would even work or not. If it doesn't then I have a vm30 for sale with another partial vm30.
- punisher11b
- Thank you received: 22
09 May 2016 15:13 - 09 May 2016 15:17 #725398
by punisher11b
- good luck
Replied by punisher11b on topic 1979 kz400 vm30
www.mikuni.com/pdf/vmmanual
there is a graph in this manual that will explain the size difference. you can get the right air fuel mix but will lower your output if too small. might not be a significant difference with the 400 though since it is lower on the output scale anyway. just my 2c
side note, I'm having trouble with the exact link. Google mikuni VM manual and it should pop up if it doesn't work.
- good luck
Last edit: 09 May 2016 15:17 by punisher11b.
The following user(s) said Thank You: dlc198322312
