1981 KZ440A LTD cylinder won't fire
- kz440
03 May 2016 17:15 - 03 May 2016 19:50 #724375
by kz440
1981 KZ440A LTD cylinder won't fire was created by kz440
All of a sudden one of my cylinders stopped firing.
I've done about everything I can think of.
I've taken apart the carbs and cleaned them .
Set the floats.
Tried turning the mixture screw but it doesn't seem to make a difference on either of the carbs.
Changed my petcock out from a vacuum one to a gravity one (My old pet cock was acting up and I figured it was just easier to eliminate the vacuum as my issue.) Capped the old vacuum port.
I have spark but changed the spark plugs any way.
Compression checked both cylinders and I'm to spec.
If I take my air pods off the one cylinder still fires but if I choke the air with my hand (on the cylinder that doesn't fire) it fires.
Which makes me believe it's not getting enough gas.
But if i loosen the screw on the drain for the bowl gas comes out.
Any thoughts would be greatly appreciated.
Set the floats.
Last edit: 03 May 2016 19:50 by kz440.
- Irish-Kawi
- Thank you received: 37
03 May 2016 17:42 - 03 May 2016 17:43 #724382
by Irish-Kawi
All the gear all the time!
1985 Kawasaki GPz 750 (ZX750-A3) 15,000 original miles www.kzrider.com/forum/11-projects/601230...z750-refresh-project
Father - Husband - Bourbonr - Rider
Replied by Irish-Kawi on topic 1981 KZ440A LTD cylinder won't fire
Have you tried changing spark plug leads to see if the problem follows the plug wire?
Brett
Brett
Last edit: 03 May 2016 17:43 by Irish-Kawi.
- kz440
03 May 2016 18:01 #724386
by kz440
Replied by kz440 on topic 1981 KZ440A LTD cylinder won't fire
Yea however the problem stays with the cylinder not the wire.
- missionkz
03 May 2016 18:22 - 03 May 2016 18:25 #724390
by missionkz
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Replied by missionkz on topic 1981 KZ440A LTD cylinder won't fire
Sounds like a leaky exhaust valve or camshaft to valve/shim clearance issue... As in too tight and holding the valve open.
Do you adjust the valve lash?
Oops I see you said compression check was good.
Bruce
1977 KZ1000A1
Last edit: 03 May 2016 18:25 by missionkz.
- kz440
03 May 2016 19:46 - 03 May 2016 19:51 #724413
by kz440
Yep compression was good. That was my first thoughts too.
Last edit: 03 May 2016 19:51 by kz440.
- missionkz
04 May 2016 01:13 #724452
by missionkz
Bruce
1977 KZ1000A1
With the engine running at a slightly fast idle, can you see if a very small shot of carb cleaner in the guilty cylinder's carb, speeds the engine up?
Bruce
1977 KZ1000A1
- kz440
04 May 2016 07:53 #724485
by kz440
You know I tried this with starter fluid but I don't remember the outcome once I get home that's the first thing I'll do and I'll post the outcome. Thanks.
- kz440
04 May 2016 15:14 #724568
by kz440
Engine does speed up however the cylinder didn't really fire.
- kz440
04 May 2016 17:33 #724597
by kz440
Ok so I took the carbs apart again and instead of matching th floats I just made the dead side a good amount more rich and sure enough it's firing. I'm going to play with it some more. I'm not sure why all of a sudden this would happen or why if the floats don't match they don't work but it's working now.
