kz650 Revvs Keep Climbing
- rekvijem
02 May 2016 12:57
I've got a 77' KZ650B1 and have an issue where when I open the throttle the tach keeps climbing until redline. I just did a top end rebuild on the engine and checked the carb boots for vacuum leaks before but haven't checked them since. Could that be it?
Also, is there an easy way to fit a vacuum operated petcock on the 77 which is just a manual one?
I hate when I forget to turn the gas off and end up with a 5ft wide puddle on the driveway.
Re: kz650 Revvs Keep Climbing
02 May 2016 13:29 - 02 May 2016 13:31
If leaving the petcock in the "ON" position results in fuel overflowing from the carbs you need to fix the carbs rather than putting a band-aid on the petcock; they should not leak a single drop even with the petcock on overnight. The fact that your carbs are messed up may be the cause of the high revving. Think about it - if the carbs are flooding when the engine is off they are flooding when the engine is running and that surplus gas may be causing the engine to rev up as it is drawn into the cylinders. If it's not being drawn into the cylinders where else would the excess gas go? Ed
Last edit: 02 May 2016 13:31 by 650ed.
The following user(s) said Thank You: rekvijem
