- Thank you received: 1
Keihin vb32 vacuum piston
- Mykzisbroke
27 Apr 2016 11:25 - 27 Apr 2016 12:21 #723273
by Mykzisbroke
Keihin vb32 vacuum piston was created by Mykzisbroke
I have a 1978 kz400 b1. I have a problem with the vacuum slide. I removed my diaphrams because they were torn. I needed to know which side the two holes are suppose to go towards when i reinstall, engine side or air filter side? Of coarse i forgot to look before i took it apart. The diaphrams origanally had a notch in them so i know the are suppose to only go one way. Any help would be greatly appreciated. Also was wondering if there is a difference between vb32 carbs and Cv32 carbs?
Last edit: 27 Apr 2016 12:21 by Mykzisbroke.
- Mykzisbroke
10 Jul 2016 18:18 #734506
by Mykzisbroke
Replied by Mykzisbroke on topic Keihin vb32 vacuum piston
I found the answer to this question if anyone needs to know. Holes go toward the air filter side.
