need carb help
  • TexasKZ
  • TexasKZ's Avatar
Re: need carb help
19 Apr 2016 20:29
#721925
  • Gregl
  • Gregl's Avatar Topic Author
Re: need carb help
19 Apr 2016 20:36
#721926
im having trouble finding an air filter. go figure
  • punisher11b
  • punisher11b's Avatar
Re: need carb help
19 Apr 2016 20:40
#721928
I have a manifold from 11th hour industries. I wouldn't recommend going that route unless you want to jet carbs. That is its own set of problems. Do you have the snorkel piece that attaches the filter to the airbox? Number 11012 in the diagram?
Attachment not found
- good luck
  • Gregl
Re: need carb help
19 Apr 2016 20:45 - 19 Apr 2016 20:47
#721929
no i just have the main air box. the top part i do not have. if i have to jet i have to jet. im looking for the easiest most reliable way to get the bikes in running shape. jesus 150 bucks. id just as soon make my own.
Last edit: 19 Apr 2016 20:47 by Gregl.
  • punisher11b
Re: need carb help
19 Apr 2016 20:52
#721931
They are hard to find for some reason, but eBay is your best bet to try and find one. if you do a search there was a guy who put a tutorial up on how to make a manifold yourself for the 440.
- good luck
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: need carb help
22 Apr 2016 03:06
#722295
Patton wrote:
Gregl wrote: i do have an air box, with no filter. i really like how it looks with the clamp on filters. is it detrimental?
Yes, it's very detrimental, especially on KZ440's, and will most likely turn your dream into a nightmare.
Good Fortune! :)
Not anymore!
Go to the bottom of page 12.
Also the 2 into 1 conversions will lose power all thru the powerband
compaired to a properly tuned dual carb setup.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • punisher11b
Re: need carb help
22 Apr 2016 07:17 - 22 Apr 2016 07:19
#722332
Power loss, nahhh. Tires still seem to burn all the same when I smash the throttle. :silly: :laugh:
- good luck
Last edit: 22 Apr 2016 07:19 by punisher11b. Reason: Long story short
