Keihin 746D Carb Rebuild Kit
- Realjimcarey
13 Apr 2016 20:11
Anyone know where I can get a Keihin 746D dual carb rebuild kit? Helping a friend rebuild his bike. He says it's a 1972 KZ400 but I cannot find a carb rebuild kit for that year/model.
Thanks in advance for any help you can provide.
Jim
Jim
- undiablo
Re: Keihin 746D Carb Rebuild Kit
14 Apr 2016 05:05
Ebay. Seach for KZ400 carb kit. It comes full, slow pilots, main jets, orings, needle, fuel mixture screw, etc. 2 kits for about 24usd...pretty cheap.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
14 Apr 2016 05:40 - 14 Apr 2016 16:48
9/10 "carb kits" are full of inferior aftermarket brass jets that may or may not match the originals. Only in extreme cases where there is a lot of damage can the original parts not be reused after cleaning.
I'd encourage you to fully break down the carbs. Yes, that means unganging them. And soaking all the various hard parts in carb dip. Then take a proper inventory by inspecting everything. 9/10 all you need are new O-rings and maybe float bowl gaskets.
Last edit: 14 Apr 2016 16:48 by Nessism.
- JR
14 Apr 2016 06:19He says it's a 1972 KZ400 but I cannot find a carb rebuild kit for that year/model.
kz400.com which is a great resource says the first 400 was made in 1974
kz400.com/HistoryFrameset.html
When you get the year pinned down try sirius consolidated inc
www.siriusconinc.com/search_result.php?s...=1&partno=&x=41&y=14
they seem to have a range of kits for the 400
- CKutz_GO
14 Apr 2016 13:19
In General, do you guys recommend buying rebuild kits or tearing down and seeing what you need?
chances are half the stuff you can re-use.. but when distributors are selling a kit for $30 or w/e and 1 float needle for $10 or making you buy bulk like Z1 and their float bowl gaskets..
- Realjimcarey
15 Apr 2016 17:47
Thanks everybody for all the great input!
