Answer me this!
  • tri650
  • tri650's Avatar Topic Author
Re: Answer me this!
09 Apr 2016 09:21
#720045
I checked them out - i ran a vent tube from each one. I thought maybe that was an issue before.
The issue still remains why did it start running fine in the middle of the ride? I was in a situation with the throttle pinned open and maybe going 30 MPH. Then it slowly started to perk up. Within a mile or two I was at full running. Again, I have had 3 weeks of hit and misses, changing, cleaning, rebuilding everything. All with the same result. If I had done something that caused the change I would feel better, but not knowing what suddenly changed is driving my crazy - or as I tell my wife when she says something is driving her "crazy", I tell her it is driving her "crazier". She loves when I do that.
  • tri650
Re: Answer me this!
10 Apr 2016 10:03
#720191
Looks like all is good. Took it out yesterday for about a 70 mile ride. Ran fine. A little stumble off of idle so I adjusted the pilot screw another 1/4 turn (now 2.5 turns out) and it went away. Seems to respond better in lower mid range also. Make give it a slight turn (about 1/8) to see if that makes it better.
Still haven't figured out what magically fixed itself, although I think it was a fuel delivery issue. Oh well, as long as it keeps running I am good. Now to finish the restoration!
  • TexasKZ
  • TexasKZ's Avatar
Re: Answer me this!
10 Apr 2016 16:54
#720225
Water in the fuel?
  • tri650
Re: Answer me this!
10 Apr 2016 18:12
#720233
I replaced the fuel 2-3 times. I think I still had some rust after cleaning. Then a seafoam issue. But I have changed out the gas a few times since then so I am confident it has good fuel. Just a mystery that it would run so good and then run like crap. Then recently it ran like it was stumbling at the beginning. Than all of a sudden, after 3 weeks of working on it, it suddenly comes alive. And this was after stumbling for about 5 miles.
If I had to make one guess I would say the petcock. The rebuilt kit was crap. It was still flowing fuel in the ON and RES positions. That was until I took the K&L stuff out and put the stock back in. The only thing is that with the old parts it still ran like crap until it suddenly came alive.
Divine intervention???
  • TexasKZ
  • TexasKZ's Avatar
Re: Answer me this!
11 Apr 2016 05:50
#720284
That may be.
  • strum
  • strum's Avatar
Re: Answer me this!
11 Apr 2016 06:02
#720287
somtehing came unstopped
Blairsville Ga.
1980 KZ1000 Shaft (sold and missed already)
2003 ZRX 1200R (sold)
2003 Concours ZG1000 (just purchased)
  • martin_csr
  • martin_csr's Avatar
Re: Answer me this!
11 Apr 2016 06:08
#720288
What's the condition of the petcock & screen? How bad is the tank rust?
What exact rebuild kit did yo get & where? I bet the problem isn't the K&L kit. it could be user error.
  • tri650
Re: Answer me this!
11 Apr 2016 07:34
#720309
The condition of the petcock is good and the screen is in very good shape. Everything was disassembled and cleaned. The O-ring that came with the K&L kit was too big and the new diaphragm would not seat properly. This was very obvious. I double checked to make sure my bike was listed on the original purchase and it was on the list. I would usually blame user error but when I put the original pieces back in it worked fine. I will order stock OEM O-ring and diaphragm in the event the original fails.
  • SWest
  • SWest's Avatar
  • 10 22 2014
