82 CSR 750 Twin, AB-> PODS / MPG
  • J_Rod_
  • J_Rod_'s Avatar Topic Author
07 Apr 2016 11:26 - 07 Apr 2016 13:34
#719739
Recently purchased an 82 CSR 750 twin. Runs great form what I can tell. Purchased with pods, no stock air box. It has been re jetted. Pilot JET is 50 i believe, will have to double check on the Main. Here are my issues.
-After idling, occasionally first twist will backfire in carb/pods.
-Also sometimes it sputters during acceleration in 4th when up around 4-5k rpm.
-some back firing during decel, but decreases when bike warms up.
-Main Issue: I'm getting around 25 mpg on avg... which based upon my reading and the stock specs is terrible.
I understand pods and bigger jets will affect fuel efficiency, but it should not cut it in half. I have yet to do a valve adjustment or a carb sync, which I plan on doing in the next week. If that doesn't solve my issue, than I am going to find a stock air box and jet-down to stock specs.
Any tips or ideas? Also.. Where the hell can I find a stock air box.. I've looked everywhere but to no avail. Thanks.
Last edit: 07 Apr 2016 13:34 by J_Rod_.
Re: 82 CSR 750 Twin, AB-> PODS / MPG
07 Apr 2016 12:00
#719744
Check with the guy in the link below. If he decides not to put his airbox back on he may be willing to sell it. Ed
www.kzrider.com/forum/3-carburetor/60195...ds-kz750-twin#719664
  • bountyhunter
  • bountyhunter's Avatar
07 Apr 2016 12:12
#719746
Sounds like it's running lean. The terrible mileage is because screwing up the air mix means you have to open the throttle a lot more to get power to run and that eats gas. Mileage on my 750 twin has alwys been around 40 mpg city only and about 55 highway cruise.
  • J_Rod_
07 Apr 2016 13:12
#719749
Thanks. I was actually able to find one on Ebay form an 83 LTD. Same airbox.
  • J_Rod_
07 Apr 2016 13:13
#719750
Yeah.. I grabbed an airbox on Ebay.. gona jet down to stock specs, give it a tune up and see where I stand. Gracias.
