VM28 Mikunis KZ1000E2
- rrsmsw9999
Re: VM28 Mikunis KZ1000E2
04 Apr 2016 10:33
If I get a bowl and replace the pump bowl, couldn't they just be capped or does that sitting gas in there cause a problem? There is the jet that gas pumps through, but that could be cover with a piece of gasket. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- strum
04 Apr 2016 11:46
Like I said before this what a guy told me but Im like steve i dont like doing something i cant undo.
really though i dont see why just taking the linkage off wouldnt give you an answer.
Blairsville Ga.
1980 KZ1000 Shaft (sold and missed already)
2003 ZRX 1200R (sold)
2003 Concours ZG1000 (just purchased)
- rrsmsw9999
04 Apr 2016 12:06
Yeah that's even more simple, but I bet the gas in there would varnish up. It might be the last time you could use em even without permanent changes. Anyway this a level 2 mod and I am still in the basement. I'll settle for running at this point.. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- strum
04 Apr 2016 12:15rrsmsw9999 wrote: Yeah that's even more simple, but I bet the gas in there would varnish up. It might be the last time you could use em even without permanent changes. Anyway this a level 2 mod and I am still in the basement. I'll settle for running at this point.. R
LOL i hear ya on that.
I went through a little aggravation with mine but I opted for making the pump/srays work.
so far mine are working well but i haven't let it sit to long .
if you make a stand to hold you carbs on the bench and hook up an auxiliary tank then you can set float levels and see if the sprays are working.
Blairsville Ga.
