GPz 750 Carburetor upgrade
  • DurbinCR
  • DurbinCR's Avatar Topic Author
31 Mar 2016 14:34
#718554
Ok guys short and sweet. I've got the stock CVs on my Unitrack 750, nothing wrong with them they work great, I just want to upgrade to flat slides. So, opinions on what model carb I should get and where to get them? Tuning advice would be welcome as well. Thanks!
1983 GPZ 750 A1 Unitrack
Re: GPz 750 Carburetor upgrade
31 Mar 2016 14:54
#718557
Is the engine stock? If so, I doubt that putting bigger carbs on it will improve overall power by much; in fact they may reduce low to midrange power. Ed
  • DurbinCR
31 Mar 2016 14:59 - 31 Mar 2016 15:01
#718559
It's stock for now with the exception of a custom exhaust I'm building for it. But eventually I want to turn this thing into a street/strip bike. Overbore, cams, head porting, the works. Also, I don't necessarily want BIGGER carbs I'd just like to swap to mechanically operated slides instead of the CVs
Last edit: 31 Mar 2016 15:01 by DurbinCR.
  • zukdave
  • zukdave's Avatar
04 Apr 2016 20:35
#719310
mechanical carb's flow more air then a cv type carb. so you don't need a bigger carb.
A 31 mm FCR flat slide or a 31 mm round slide CR Special would work nice on a built 810 cc motor
I'll be replacing my VM29's with one or the other after I do cams.
Myself I think you should build the motor first before you spent $600 to $800 on a set of
carb's that might not work well with how you built the motor.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • Kawboy74
  • Kawboy74's Avatar
10 Apr 2016 11:41
#720200
What year is your GPZ? I am currently working on an '88 model and am losing my mind trying to get the airbox boots onto the carbs and then keeping them there with those cruddy weak springs. I know on the KZ stuff the airbox is there to stay to limit tuning headaches and more necessary on the CV type but I am ready to try pods anyway. Have you been running the airbox on the stock carbs?
David
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
  • DurbinCR
10 Apr 2016 12:42
#720204
Mine is an 83. And I hear you about the air boots. I honestly had mine taped on for a while :laugh:
Right now I've jetted my carbs for pods and I'm building a kind of intake manifold for them. If it works good I'll post pictures and a how to on here. Good luck with yours.
  • riturbo
  • riturbo's Avatar
11 Apr 2016 05:54
#720285
The rubbers are pain . I drop the wife's blow dryer in the air box and heat them up for a while . Seems to soften them up .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
