Found cold start problem, bad carb design!!!?????
- car5car
- Banned
30 Mar 2016 17:01 - 30 Mar 2016 17:14
Cold start gas sucking tube has 3 levels of holes:
bottom 1 hole
middle level 2 holes
top level 4 holes.
I think, top 4 holes suck air, not gas, because when bike is on side stand, half of the pipe is not under gas level. Pipes are located of right side of carbs.
Does it make sense?
I cleaned all holes, they seem OK. Cold start is better but still not perfect.
OK, I guess, I didn't clean cold start jet again. It is not in the pipe, it is in bowl. (diagram)
How do you clean it?
Is this hole for cold start?
bottom 1 hole
top level 4 holes.
Does it make sense?
Attachment IMG_1334.JPG not found
Attachment IMG_1342.JPG not found
Attachment coldstartdiagram.jpg not found
96 Yamaha Royal Star
82 Yamaha Virago 920
Last edit: 30 Mar 2016 17:14 by car5car.
Re: Found cold start problem, bad carb design!!!?????
30 Mar 2016 17:41
On the bottom of the tube is the jet. It must be clear. My 33's have a larger one at the bottom of the bowl too. I always had a lean condition when using the choke. It worked but popped and spit out of the carbs. This time around I used my jet drills and made it two steps larger. It works better. The holes on the sides mix the air like the emulsion tubes in the main jet circuit.
The following user(s) said Thank You: car5car
- car5car
- Banned
31 Mar 2016 04:41
Thanks!
- car5car
- Banned
31 Mar 2016 19:53That is exactly what happens with mine. I cleaned all holes with needle, I know they are OK.swest wrote: I always had a lean condition when using the choke. It worked but popped and spit out of the carbs. This time around I used my jet drills and made it two steps larger. It works better. The holes on the sides mix the air like the emulsion tubes in the main jet circuit.
Thanks, Steve.
There are many good bike mechanics here!
31 Mar 2016 20:05
A guitar string is good for that.
