Kz750 LTD 1981 pod
  • Jo714
  • Jo714's Avatar Topic Author
Kz750 LTD 1981 pod
27 Mar 2016 06:13
#717542
Hi, i'm new here and not so good in english.
I have a 1981 kz750 Ltd with pod. The last owner does'nt change the jet. I see a couple of variation in the jet number to put inside. What are you thinking about that?
Thanks
  • TexasKZ
  • TexasKZ's Avatar
Re: Kz750 LTD 1981 pod
27 Mar 2016 06:26 - 27 Mar 2016 06:28
#717546
Hi Jo714, welcome to the madness.
Is it a twin or four cylinder model?
Many factors can affect the final set up. Does the bike have factory exhaust? Aftermarket cams or other internal modifications? Stock carburetors? Do you normally ride at high altitude or near sea level?
Has all the routine maintenance been performed lately? If not, that needs to be taken care of before messing with the jets. A genuine Kawasaki Service Manual will be invaluable.
Be prepared for a long process of trial and error. It might be a good idea to search this site for a pod filter thread concerning a bike set up like yours and ridden at similar altitude.
There are several 750 owners here who can probably give you a good starting point.
Last edit: 27 Mar 2016 06:28 by TexasKZ.
  • Jo714
27 Mar 2016 07:11
#717560
Hi, yes stock carburetor with , stock exhaust.
I just change spark plug and cable, oil.
I live near Montréal in Québec, canada
  • martin_csr
  • martin_csr's Avatar
27 Mar 2016 08:06 - 28 Mar 2016 06:12
#717576
my mistake.
Last edit: 28 Mar 2016 06:12 by martin_csr.
  • Jo714
27 Mar 2016 08:18
#717579
Thanks but its not an option
  • KZ802
  • KZ802's Avatar
27 Mar 2016 13:27
#717620
I have the same bike- 1980 LTD 750. I put a dynojet stage 3 jet kit on and vance and hines 4-1 pipe and pod filters. It did not take much more to get it dialed in besides synching carbs. My stock pipe was junk and I wanna say the V&H pipe was only like $350? Sounds awesome and looks good. I can't remember the jet size I just followed the directions with the kit. Of course if you want to keep the setup you have and not change the pipe you would need different jets.By the way I'm just south of you in Burlington VT.
1980 KZ750 LTDx2
1978 KZ1000 LTD
1976 KZ900 A
  • Nebr_Rex
  • Nebr_Rex's Avatar
27 Mar 2016 17:14
#717648
The DynoJet jet kit comes with stage 1 and 3. Both stages come with 2 different size jets.
Stage 1 is for the stock airbox with or without an aftermarket exhaust.
Stage 3 is for individual filters.
DynoJet jets are numbered differently than the Mikuni or Keihin jets.
The crossreference chart is posted all over the net.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
