Carb screws
- Maarrrccc
Carb screws
23 Mar 2016 17:24
So I scored a kz700 for free for my first bike. Friend said it sat for about 2 years but before that ran great. I went ahead and started taking apart the carbs to clean them. The screws for the top and bowls were just old and worn and now they're stripped. Trying to source screws or allen head bolts for the tops and bowls of my carbs now. Any advice on where to look or sizes or anything. Thanks in advance.
Re: Carb screws
23 Mar 2016 17:57
You can get SS Allens at your hardware store or HD.
- jdvorchak
Re: Carb screws
25 Mar 2016 07:22
First of all buy at least a #2 JIS screwdriver. Stop stripping the heads out of these old bikes screws. with Phillips screwdrivers.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
John
83 KZ550M1
83 KZ1100LTD
Also own:
Re: Carb screws
25 Mar 2016 07:48
Like jd said, despite how they look, Kawasaki did not use Phillips head screws. Those are JIS and you will have far fewer problems using a screwdriver that fits properly. You can buy them cheaply enough fom Z1Enterprise, or you ca fire up you grinder and modify a Phillps to fit.
If you want to change to Allen head fasteners, Z1E or any decent hardware store should be able to fix you up with the proper size metric fasteners.
Re: Carb screws
25 Mar 2016 08:18
I like the Z1 Enterprises screws since they contain a captive lock washer.
