Rubber hoses attached to bowl ventilation pipe?
  • car5car
  • car5car's Avatar Topic Author
  • Banned
  • Banned
15 Mar 2016 21:35 - 15 Mar 2016 21:52
#715628
79 kz1000 manual shows a picture with rubber hoses attached to bowl ventilation pipe.
My carbs don't have them. Are they necessary?
Attachment ventbowlhoses.jpg not found
96 Yamaha Royal Star
82 Yamaha Virago 920
Last edit: 15 Mar 2016 21:52 by car5car.
  • bountyhunter
  • bountyhunter's Avatar
Re: Rubber hoses attached to bowl ventilation pipe?
16 Mar 2016 01:22 - 16 Mar 2016 01:24
#715632
The tubes on the overflow pipes allow the gas coming out to run down and not make a mess. If the needle valves are not sealing well, you can get gas dumping out which will drip down onto the bike.
The hoses on the vent pipes keep junk from getting in the carbs.
Last edit: 16 Mar 2016 01:24 by bountyhunter.
  • Nessism
  • Nessism's Avatar
16 Mar 2016 05:55
#715640
Best to have the tubes and route them away from the exhaust and rear wheel. If you get a leak you want the fuel to stay away from a heat source and your back tire.
