Brand New Keihin Carbs - bike won't turn over
- kawasakisubaru
10 Mar 2016 16:00
I just purchased a set of Keihin CR29 carbs from dynoman performance.
I also installed new dyna coils.
Installation was easy. I hooked up the gas line, let it sit with the petcock open for about 2-3 minutes to let the float bowl fill.
Upon pressing the starter button the bike did some popping and sounded like it wanted to turn over, but never did.
I check each spark plug to make sure its receiving a spark - each plug had a spark and i could even see a little black deposit on it.
Plugs #3 and #4 even had a little wet residue on it. Leading me to believe, if anything, its a little rich.
Checked the intake boots for leaks, and retightened the clamps around the spigot.
My carbs are set as such:
Main 120
Air Jet 250
Needle YY8 on clip 4
Slow Jet 60
And I think, but I'm not sure, they came from dynoman performance with the air screw 1 1/4 turns out, which is what I've heard its a "stock" setting.
Can anyone help?
Main 120
Air Jet 250
Slow Jet 60
Can anyone help?
1980 KZ750 E1
Kerker by Kawasaki 4-1 exhaust
Lockhart oil cooler
Mikuni VM29 smoothbore carbs
Pingel high flow petcock
Dunlop K70s
Custom brat style seat
Clubman bars
Dime city cycles 1.5in tach/speedo
Ox blood grips
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
- rstnick
Re: Brand New Keihin Carbs - bike won't turn over
10 Mar 2016 17:28 - 10 Mar 2016 17:39
You say the bike wont turn over.
Do you mean the electric start will not crank the engine over?
Or that she is turning over, but wont start?
You added new coils, so double check the wiring.
The mounting posts on Dyna coils are very close to the wire connections, depending on which holes you use.
If this is the case for yours, wrap the posts with something to prevent power from jumping over to the mounting posts.
Also try swapping the two wires going to the coils from the ignition system, they are usually green and black wires.
If they are backwards, the spark plugs will still spark, but at the wrong time.
In the picture below, notice the blue plastic wrapping the right post:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
Last edit: 10 Mar 2016 17:39 by rstnick.
- kawasakisubaru
10 Mar 2016 17:54
I figured out the issue. I hadn't properly plugged one of the wires into the dyna coil, those SOB's were tough to get on.
Thanks for that picture rstnick. I had noticed those screws were pretty close to the wires, I'll wrap them in some insulation, that looks like a good idea.
1980 KZ750 E1
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
- eddiem
- KZR FLAG RELAY CARRIER #63
10 Mar 2016 19:11
Are you running the stock air box?
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
