What is this? Triangle cover next to accel pump
  • car5car
  • car5car's Avatar Topic Author
  • Banned
  • Banned
08 Mar 2016 13:24
#714502
Looks like gasket disappeared.
Attachment carbcover.jpg not found
96 Yamaha Royal Star
82 Yamaha Virago 920
  • zed1015
  • zed1015's Avatar
Re: What is this? Triangle cover next to accel pump
08 Mar 2016 15:15 - 08 Mar 2016 15:17
#714521
I presume those carbs are 28mm.
That cover is redundant on those and is used to house a diaphragm on the 26mm version .
Google vm26mm pumper carbs or look on WG carbs web site for full details..
Last edit: 08 Mar 2016 15:17 by zed1015.
  • martin_csr
  • martin_csr's Avatar
09 Mar 2016 07:23 - 09 Mar 2016 07:27
#714606
That's the vacuum sensor. the vac sensor diaphragm has a brass plunger that pushes on a steel ball. I think it allows fuel to flow to the AP when the engine is running, but stops the flow when the engine stops. it's kind of a rube goldberg epa type of thing
On some models the device was disabled at the factory, as on the 81 650. mine didn't have the cover & the orifices on the flange aren't factory drilled or anything. kinda puzzling at first, especially since I didn't know anything about carburetors at the time. the rebuild kit had this triangular thing that wouldn't fit. doh.
Last edit: 09 Mar 2016 07:27 by martin_csr.
