- Thank you received: 20
Are float valve rings metal or rubber or?
- car5car
- Banned
08 Mar 2016 09:35 #714477
by car5car
96 Yamaha Royal Star
82 Yamaha Virago 920
Are float valve rings metal or rubber or? was created by car5car
I bought used valves from ebay, they came with aluminum o rings. O-rings in my carbs look like gasket material.
Which ones are right?
Thanks.
I guess I have bad valves AND bad petcock.
Thanks.
- rstnick
- Thank you received: 377
08 Mar 2016 17:53 - 08 Mar 2016 17:55 #714544
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic Are float valve rings metal or rubber or?
Not sure on your model, but on my 650c2 the seal under(above) the float/fuel valve seat is a gasket, maybe even cork.
They are brownish in colour.
The 650's from Z1E:
www.z1enterprises.com/product/SU002-187
The '80 kz1000 st seems to use the same type:
The 650's from Z1E:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: 08 Mar 2016 17:55 by rstnick.
