install mikuni 32vm roundslide carb on kz400
- GILTYGIL
02 Mar 2016 18:34
the tank valve has a 21mm spread .the carb has no vac port valve must have vac to operate. all manual valves have 3 4mm bolt spread or larger! anyone have a solution ?
Re: install mikuni 32vm roundslide carb on kz400
02 Mar 2016 18:53
Drill
Brass tube
Rubber cement or sealant
Make your own vacuum port in the intake manifold.
Brass tube
- Nebr_Rex
02 Mar 2016 19:08GILTYGIL wrote: the tank valve has a 21mm spread .the carb has no vac port valve must have vac to operate. all manual valves have 3 4mm bolt spread or larger! anyone have a solution ?
? :huh:
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
02 Mar 2016 19:31
03 Mar 2016 06:37
There may also be a spot on the carburetor where a port can be added, but do not try this option unless you have talked to somrbody who has successfully done so on this particular model of carb. A small error could be catastrophic.
