Build Your Own Throttle Cables
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
25 Feb 2016 11:34 - 25 Feb 2016 19:12
#712481
:) Anyone here used a KNARP for a throttle cable?
In my diligent but failed quest to find ready-made throttle cables for an obsolete Kawasaki dual cable throttle control, I found what appears to be the perfect solution. :cheer:
www.1977mopeds.com/Cable-Stop-Throttle-Knarp-5-5mm-p/418.htm
At this point, I've resolved to make two cables from four.
With the curved steel end-pieces (specific for the control) from two used cable assemblies, and the outer protective sheath (with carb-end adjuster/nuts) from two others, can then build them with the inner-cables cut to the exact lengths needed....with just one KNARP each :whistle:
1982 KZ1100-A2
Last edit: 25 Feb 2016 19:12 by daveo.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Build Your Own Throttle Cables
26 Feb 2016 06:28
#712564
i have used them on cables for my banshees before.
they worked just like they we're supposed to.
26 Feb 2016 07:10
#712567
For those interested, several varieties of mechanically attached cable ends are available.
various types of cable ends
As known, the old fashion method for attaching a standard cable end is to insert the cable through an end, spread the cable tip strands before soldering amongst the spread strands, in order to prevent the cable from pulling back through the end, which may be ground smooth.
old fashion method
Good Fortune! :)
