TK 22 float bowl bolt size?
- MadShad
22 Feb 2016 08:16 - 22 Feb 2016 10:12
I've had my GPz550 for about 2 weeks, in that time I've had the bowls off the carbs several times.
I want to put allen head bolts in the bowl instead of phillips or jis.
Anybody know what size they are?
I'm going to stop by a hobby shop and try to pick some up tonight and can't get to my bike.
M4? M3? And how long? Thanks!
Shelbyville, Indiana. '80 KZ1000
No more of that talk or I'll put the leeches on you, understand?
Last edit: 22 Feb 2016 10:12 by MadShad.
Re: TK 22 float bowl bolt size?
22 Feb 2016 10:41
Take one off and go to the hardware store.
- rrsmsw9999
22 Feb 2016 11:18
4x16
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- MadShad
22 Feb 2016 11:20
Thank you kind sir!
- loudhvx
22 Feb 2016 14:16 - 22 Feb 2016 14:18
I like to run a tap through the holes before using long allens. Some of the holes seem to not have been threaded entirely all the way.
Also, I use a tiny bit of antiseize on the gaskets (and screws) and they come off like new everytime. I've used the same gaskets through dozens of rejets over 20 years.
And, of course, stainless gets you extra style points.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 22 Feb 2016 14:18 by loudhvx.
- MadShad
22 Feb 2016 14:49
I ordered 12 gaskets just to have on hand, but I will try the antiseize, better than tearing a gasket and having it stick to the carb body on #2 or #3.
Never guessed I'd be in there that often but between tracking down my leak and rejetting I'm wearing out the stock hardware.
22 Feb 2016 15:51
If you coat the gaskets with a thin coat of grease you can reuse them. I haven't bought them for my carbs in 20 years.
- MadShad
22 Feb 2016 15:53
I have used the grease trick on several case gaskets, problem is I've always sold the bikes before they had to come back apart so I have no idea if it worked or not, ha!
