Warning: Undefined variable $end_tag_params in /home/kzride5/public_html/libraries/kunena/External/Nbbc/src/BBCode.php on line 2321
New member, likely an old question..
  • HankSD
  • HankSD's Avatar Topic Author
06 Feb 2016 14:32
#709738
Hi all. I'm new here.
I picked up this '83 as a project. Its nearly complete and not bad shape, and low miles.
[IMG
The airbox seems to be missing some parts. Off to ebay I go. Are those little tiny triangular filters on the back corners of the airbox all it has? Holy crap that seems inadequate?
I yanked the carbs today and they aren't too bad, but I'm wondering about these little plugs in the carbs. Should they fit snug in the holes? They basically fall out, which doesn't make sense. The jet underneath it was plugged on two of four. All other jets clean. Most of the o-rings are pretty stiff.
[IMG
I'll chedk out Z1 enterprises for parts soon.
Thanks!
  • zukdave
  • zukdave's Avatar
Re: New member, likely an old question..
06 Feb 2016 15:01
#709743
Need's a new o-ring if it fall's out plus the old one is NOT sealing.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
The following user(s) said Thank You: HankSD
  • Nessism
  • Nessism's Avatar
  • HankSD
07 Feb 2016 11:33
#709853
I ordered 4 carb kits from Z1. Hopefully it includes that little o-ring.
The previous owner found the missing airbox parts for me too.
  • Nessism
  • Nessism's Avatar
07 Feb 2016 14:58
#709872
Carb kits suck. All full of inferior brass. You would be better off reusing the stock jets and getting new o rings
07 Feb 2016 15:12 - 07 Feb 2016 15:12
#709875
Nessism wrote: Carb kits suck. All full of inferior brass. You would be better off reusing the stock jets and getting new o rings
+1 If the original metal parts haven't been physically mutilated by a previous owner why replace them? Ed
Last edit: 07 Feb 2016 15:12 by 650ed.
  • HankSD
08 Feb 2016 01:35
#709907
Good point. Mostly because its one way, although an expensive one, to find all the right o-rings.
I'll plan to re-use the stock jets.
  • jdvorchak
  • jdvorchak's Avatar
10 Feb 2016 04:26
#710259
No eBay APP ID and/or Cert ID defined in Kunena configurationI got tired of the high price of OEM o-rings and trying to hunt them down. So I bought this set on eBay and now have a lifetime supply:
Over the past 6 months I've used o-rings from this set about a dozen times. But I work on a lot of bikes. What convinced me to buy the o-ring assortment was tracking down an o-ring where I needed 2 of them and they were about $9 each. So this kit paid for itself on the first use.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
  • SWest
  • SWest's Avatar
  • 10 22 2014
10 Feb 2016 04:44 - 10 Feb 2016 04:45
#710260
Most O rings I get from my local auto parts store. Some I can get at the local ACE. The carb O rings I get from jetsRus as long as I have other things to buy to off set the $7 handling charge. I find the kits rarely have what I need.
jetsrus.com/parts/orings.html
Last edit: 10 Feb 2016 04:45 by SWest.
  • KZB2 650
  • KZB2 650's Avatar
10 Feb 2016 05:26
#710261
Harbor freight has the same kit for just over 6.50 w/ the 20% off coupon and they sell a viton kit too....... not sure if the sizes are close enough though like Steve says for carb work...... picked up one the other day.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • HankSD
21 Feb 2016 06:00 - 21 Feb 2016 06:01
#711761
Well the K&L rebuild kits provided little value other than the bowl o-ring and a couple other o-rings. I guess i used their bowl screws.
I bought an o-ring kit off Amazon and used that for the fuel connections and the plastic plugs in the bowls. The KL ones were way too big for the plugs and it didn't have any for the fuel connections.
I got the float levels set on the bench with a clear tube, ~6mm below the bowl / body seam. Checked the valve clearances, all in spec but a lot were on the edge. Good enough for now till I make sure there are no other problems.
I thought the battery was taking a charge, but it appears its junk, so this morning I'll run to town and get a new one. Hopefully it fires up and I'll sync the carbs and give it an oil change.
Once its running and has no apparent major problems, I'll order up tires and fork seals, and probably dismantle the rear suspension and steering head for a good greasing.
Last edit: 21 Feb 2016 06:01 by HankSD.
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 Feb 2016 07:05
#711773
I don't know why I've been dragging my feet buying O rings from JRU. I've been living with a couple buggered up air bleed screws and the O rings are gone.
jetsrus.com/individual_parts/002_677_su.html
jetsrus.com/individual_parts/002_676_su.html
$31.49 and I can cross off another undone from my list. What a dog head. :blush:
