kz400 re-assembly help
- phelps4u
24 Jan 2016 05:36 #707850
by phelps4u
kz400 re-assembly help was created by phelps4u
Hello fellow riders. Not an actual rider yet considering the project ahead. I bought a 78 kz400 for $200 basically in a heap of parts less carb set and air box. I have been able to find the parts but have a question. Is the carb set supported by a bracket somewhere on the frame or is it supported by the combination of the boots on the engine and air box? If anyone can send or has a link to a picture of the engine/carb area with the tank off it would help.
Thanks
Thanks
- Thank you received: 1656
24 Jan 2016 05:58 - 24 Jan 2016 06:07 #707856
by martin_csr
Replied by martin_csr on topic kz400 re-assembly help
The carburetors are typically supported by the rubber carb holders at the cylinder head & the airbox inlet ducts.
My 81 650 has brackets that secure the airbox to the battey case. not sure about your 400.
The diagrams at Kawasaki.com or Partzilla should help in figuring out some stuff.
Last edit: 24 Jan 2016 06:07 by martin_csr.
The following user(s) said Thank You: phelps4u
- pete greek1
- Thank you received: 185
24 Jan 2016 07:41 #707863
by pete greek1
Replied by pete greek1 on topic kz400 re-assembly help
The carbs are basically only held on by the intake boots, as you can see ,with no air box & bigger than stock carbs
Pete
Pete
- jdvorchak
- Thank you received: 50
26 Jan 2016 03:53 #708160
by jdvorchak
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
Replied by jdvorchak on topic kz400 re-assembly help
If you think they need more than just the carb holders on the head, you've never tried to pull a rack off of an old bike....LOL
One tip I use is to lube the inside of the carb holders with dialectic grease or just plain Vaseline or silicon. Put a lite coat on the carb throats and they will slip in easier. Not easy... but easier. Check Youtube for various methods of using clamps or tie down straps to install them into the carb holders.
John
83 KZ550M1
83 KZ1100LTD
Also own:
