VM28 or Vm26 Pumpers
  • Carnage
  • Carnage's Avatar Topic Author
05 Jan 2016 13:41
#705724
i'm building a mild 1075 10.5-1 comp ,ported heat , 5 angle valve job , with GPZ cam , 4-1 Kerker with baffle , Dyna ignition and good foam pods , should i go with VM28s or VM26 pumpers , i got both in stock now
less is more
  • floivanus
  • floivanus's Avatar
Re: VM28 or Vm26 Pumpers
05 Jan 2016 14:17
#705728
Uh, 28s at the very least, I'm sure somebody will say 29 smoothbores, that's a lot to even consider 26s for
Past; 78 kz1000, 83 kz550
Andrew
  • Carnage
05 Jan 2016 14:26 - 06 Jan 2016 11:43
#705729
i have access to 34 Keinhs , but i dont wanna use venturi carbs
less is more
Last edit: 06 Jan 2016 11:43 by Carnage.
  • DFIGPZ
  • DFIGPZ's Avatar
05 Jan 2016 17:24
#705742
VM28
1984 750 Turbo
  • redhawk4
  • redhawk4's Avatar
06 Jan 2016 07:42 - 06 Jan 2016 07:49
#705779
Most, if not all of the power increase from 83 -90 hp on the Z1R, over the stock KZ1000, comes from the 28mm carbs vs 26mm as the rest of the motor and cams are the same, the only other difference being the 4-1 exhaust, which I don't know was more efficient than the 4-2 factory system. So of the choices you have I would definitely go for 28mm.
I have the same big bore kit on mine and the 28mm carbs and certainly don't see any downside in terms of the supposed reasons Kawasaki went to the 26mm carbs on the KZ1000, If you are making the other mods to help the head flow, then you need the bigger carbs for certain and even they may not be enough to fulfill the potential of your build.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
Last edit: 06 Jan 2016 07:49 by redhawk4.
  • GregZ
  • GregZ's Avatar
06 Jan 2016 12:56
#705804
Do yourself a favor and get some 29 smoothbores,period
  • floivanus
06 Jan 2016 13:23
#705807
^^^^ see, told you someone would say it.
With all the work, cant see where you would consider 26s.
Andrew
  • Carnage
06 Jan 2016 13:36
#705810
It's my first bike build , i do v-8s and v-dubs usualy
less is more
  • Rockranch
  • Rockranch's Avatar
06 Jan 2016 14:09
#705816
With the mods, bigger is the definite plus. U can't go wrong. Adjustments from there are easy.
(2)-1976 KZ900B-LTD's
1-all stock low mileage...
1 modified
1977 KZ1000 (awaiting resurrection!) :)
...and an old school Honda CB750 Chopper is next on my bucket list!
Oh...and a Pocket Rocket lol!!!
  • missionkz
  • missionkz's Avatar
06 Jan 2016 14:11
#705817
I'm running Wiseco 1075cc, 10.25:1 Pistons with 4 into 1 Denco headers, stock 26mm carbs, jetted pretty close , fresh head and valves.... and this thing hauls serious ASS!!
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • redhawk4
  • redhawk4's Avatar
06 Jan 2016 14:49 - 06 Jan 2016 14:50
#705831
missionkz wrote: I'm running Wiseco 1075cc, 10.25:1 Pistons with 4 into 1 Denco headers, stock 26mm carbs, jetted pretty close , fresh head and valves.... and this thing hauls serious ASS!!
Bikes run good with 26's, but if you were as lucky as the OP to have a set of 28's lying around at your disposal I don't doubt they'd find a way onto your bike :)
With the GPZ cams etc. you'd definitely want the 28's IMO, even a stock bike can benefit from 28's hence my original comments about the Z1R. The benefits of smaller carbs are usually that they are easier to tune and idle better at the expense of some top end power.
1977 KZ650B1
1980 Suzuki SP400
Last edit: 06 Jan 2016 14:50 by redhawk4.
  • DFIGPZ
  • DFIGPZ's Avatar
06 Jan 2016 18:50
#705851
29 Smoothbores are not worth the added $ over a set of VM28's on this type of build.
1984 750 Turbo
