Mikuni reality check
- retterath
20 Dec 2015 19:22
This is normal, right?
Looks just like this one from APE
I'm assuming this cut o-ring goes with the accelerator pump?
And I have leaky carb holders. Will the stock ones work, or do I need something special because of the Mikunis?
Thanks.
Thanks.
- floivanus
Re: Mikuni reality check
21 Dec 2015 01:09
What carbs and bike? Nearly ALL kzs came with mikuni carbs (minus a few with keihin carbs) so you gotta be a littld more exact (bike model, carb size etc)
And what looks normal?
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- retterath
21 Dec 2015 05:38
RS34s on a 1980 kz1000 LTD. The fuel supply tube between float bowls is not centered and is missing an o-ring.
- floivanus
21 Dec 2015 06:38
I'm sure it isn't supposed to be missing the o-ring; but if you have had fuel in it, and it doesn't leak you should be okay. There's probably a second groove with an o-ring.
Being 34s you are most likely going to need something other than the stock boots, which are made for vm26-28 carbs. Probably ones from an 81-up 1000 which used bs34 carbs would work?
Andrew
Andrew
21 Dec 2015 07:14
That's what I'm using with my 33's.
- retterath
23 Jan 2016 08:50 - 23 Jan 2016 08:55
So i ordered what I thought were "new" oem carb holders off fleebay. They are rock hard, and look used to me. Do they come from the factory with cylinder head imprints burned in?
They are going back for sure, I'm trying to determine whether this was an honest mistake, or fraud.
Last edit: 23 Jan 2016 08:55 by retterath.
23 Jan 2016 11:37
JUNK, not as described. Leave a bad review after you get your money back including shipping. Can you post a link to your sale? I'd like to see who it is.
- z1kzonly
23 Jan 2016 11:47swest wrote: JUNK, not as described. Leave a bad review after you get your money back including shipping. Can you post a link to your sale? I'd like to see who it is.
Really!! Steve is Correct!!! Post this low life eBay seller!! Trying to pawn off these boots!!
Total JUNK! He needs his hands placed on red hot exhaust pipes IMO.
If that don't work? Then cut off his thumbs with a cutoff wheel with a 1/4" die grinder.
Then push his cut off thumbs through his eyeball sockets!
Can you tell, I have had a bad day with the IRS???????
- retterath
23 Jan 2016 12:00
They came from badboy motorsports. Will post a link when I get home. Just ordered OEM from the dealership. Hopefully the third time is the charm.
- kaw-a-holic
23 Jan 2016 13:21
Those carbs are total junk, you should just sell them to me. :evil:
Hope you get the right carb holders this time. I ordered mine from Z1.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- retterath
23 Jan 2016 13:27
I couldn't find them on Z1enterprises. I tried. That was my first choice. Just the older, smaller ones.
23 Jan 2016 13:35 - 23 Jan 2016 13:42
I got these.
www.diablocycle.com/Carb-Holders-Kawasak...1000-and-KZ1100.html
You can try here.
jbmindustries.com/
jetsrus.com/mounting_flanges/mounting_flanges.html#mikunirubber
jetsrus.com/individual_parts/KL_11_4853.html
You can try here.
jbmindustries.com/
Last edit: 23 Jan 2016 13:42 by SWest.
