Help identifying carbs
- zukdave
Re: Help identifying carbs
12 Dec 2015 18:17
VM22's have an air bleed at 10 0-clock those don't have it.
VM29's do not have the rib's.
I have read there was an add on pump for the vm carb's I'd bet thats what you have
Myself I'd find a set of carbs and not run those as parts may be APITA to find.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
12 Dec 2015 18:44
Might be easy to add NOS to those :whistle:
The following user(s) said Thank You: 750Kruzer
12 Dec 2015 23:42 - 12 Dec 2015 23:46
I would investigate removing the pump. Since it appears to be an add-on, getting rid of it may not be too problematic. After removing the nozzles & if the holes are threaded, you could install some brass plugs. Or the pod filters may sufficiently block the holes, so you may not need to plug them. ???
Last edit: 12 Dec 2015 23:46 by martin_csr.
- zukdave
13 Dec 2015 04:52TexasKZ wrote: Might be easy to add NOS to those :whistle:
I'd NEVER spray from the air box side of a carb. I've seen slide's freeze
wide open doing that.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- xxsierraxx
13 Dec 2015 05:19
So they are VM24's. The others I was referring to are not Vm29's but 26's. As was mentioned, on the advice of wired George I found a set of non accelerator pump 26's and that solved all my problems on my KZ1000. I didn't realize there was an add on pump like this so I'll just remove and see what happens. These have adjustable pilot and air screws so I should be able to make them work. I am just going to clean it up and get everything running. No plans to race or too many highway trips as i have bigger bikes for that. Thanks for all the input.
1979 KZ1000
1981 CSR 650
Honda "cough"
1981 CSR 650
Honda "cough"
13 Dec 2015 05:59
Pic of the pump? I might be interested.
- xxsierraxx
13 Dec 2015 14:33Once I get it running good without the pump I'll get rid of. I'll get you more photos then.swest wrote: Pic of the pump? I might be interested.
1979 KZ1000
1981 CSR 650
Honda "cough"
1981 CSR 650
Honda "cough"
