Carb with pinched tube
  • johnnymoff
  • johnnymoff's Avatar Topic Author
Re: Carb with pinched tube
17 Nov 2015 03:55
#699060
I measure basically, the same except I did not take the tube out yet so can't say how much is pressed into the carb.
I measured:
Outside diameter is 3mm
24mm of the tube exposed,
4mm in the recess
? holding in the carb body - I assume it is the same as yours.
I will PM you.
Engine: 77 KZ1000 A1
Frame: 78 KZ1000 B2
Carb Type: VM 26 with accelerator pump.
Needle clip: 3rd (middle) position
Pod air filters
Main Jet 132.5
Idle Jet 20
Clip position on needle 3rd (middle)
Exhaust 4 into 1 Vance and Hines
PO says 1170 kit installed.
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Nov 2015 05:07
#699073
I'd hop on it. They don't sell those parts.
  • redhawk4
  • redhawk4's Avatar
17 Nov 2015 05:26
#699080
Part going in the mail today.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • johnnymoff
17 Nov 2015 06:55
#699088
Nice!
Thanks a ton!
Frame: 78 KZ1000 B2
Pod air filters
Main Jet 132.5
Idle Jet 20
