- Thank you received: 229
An attempt at pod customization (440)
- zukdave
with the choke half on.
Pod's on cv carbs will work just fine if you learn how they work and
get passed it's the jetting it takes more more work then that but it can be done..
Oh wait your buildin a bobber never mind.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- Stauffer1024
My next step will be putting the new exhaust on then I'll get back and update this.
1980 KZ440 Ltd.
- dom2570
- Thank you received: 27
Whip it like a mule!
- Stauffer1024
zukdave wrote: This right here is some funny shit it don't run above 4 grand because you're basically running around
It's common on pod conversions with the 440 for people to cover part of the pod to get the right performance out of the carbs. This is a way to keep that same thing concealed and looking better. I was considering shaving down the 1 "sleeve end inside the pod if it is still running rich now that I went to the stock jetting.
1980 KZ440 Ltd.
- floivanus
- Thank you received: 116
BUT instead of just getting them to work with the pods, the answer is to throw a restriction in there? I dunno if it's the best route BUT I'm watching anyway
Past; 78 kz1000, 83 kz550
Andrew
- Thank you received: 2829
Stauffer1024 wrote: Okay so I finally got around to this project. It's been real cold here in PA and I don't have a garage so doing work on the bike has slowed. Anyway my Idea was to port the pods to reduce airflow so I could go down to a more reasonable jet size.......
Notice in jdvorchak’s posting where he states:
“The base problem, as I see it, is the incoming air passing though the throat actually causes a vacuum which lifts the slide. Bernoulli principal of fluid dynamics. Now the problem with running pods is that the ambient air pressure in the pod is basically outside air pressure while the air pressure inside the air filter box is lower than outside pressure. Because of this the slide is easier to pull up.”
Given that fact, now take a look at the comments and video in the posting at www.kzrider.com/forum/3-carburetor/59838...kz750-b1-1976#674519
That should show you how the diaphragm is normally affected by vacuum rather than just the diameter of the air filter thoat. Some of this info may be helpful. Ed
- Nebr_Rex
- Thank you received: 300
of pvc. Get some K@Ns or Unis that do not block the air bleeds.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- TIAGOSANTOS
Let us know how your project is going! Thanks!
Attachment 12959326_10153680528022695_807931599_o.jpg not found
