Ltd 550 street fighter build
- Gjason89
29 Oct 2015 04:40
It's been a while that I get on but every time I seek help it appears to always be on this forum. So I was having problems with my 82 ltd 550 carb they would over fill so I decided so get them rebuild it apears one of the I guess feet or however you would call them were the needle goes into to hold the float in place has broken off and so I don't know if to get it fixed and how or to try and buy a new one . If someone can help guide me the right way thanks .
Re: Ltd 550 street fighter build
29 Oct 2015 04:56
Are you talking about the tang on the float?
Pics would help.
Pics would help.
- Gjason89
29 Oct 2015 05:10
Yes the tang I just wasn't sure what to call it. Inside each bowl it has I gues two tangs and the float will go in between it and slide the needle threw the wholes on both tangs on one it broke off I'm sure I could find it but not sure what to do if to fix it or weld it somehow or what.
29 Oct 2015 05:16
There's one tang where the needle sits. Are you talking about where the pivot shaft goes through? Pics?
- Gjason89
29 Oct 2015 05:37
Ok I will post pics today when I am with the carb just to make sure we are talking about the same thing but I might of explained wrong when I say needle I don't mean the ones for the gas I mean the little I guess shaft that holds the float in place to let it go up and down as the gas goes up and down well we're the shaft hold In place on both feet that are part of the carb they have wholes and hold the shaft in place one has broken off
- floivanus
29 Oct 2015 05:41
You have a few options on that, from easiest to worst; get a new carb body and swap it out, send it to a micro TIG outfit for repair, file both pieces flat and drill/tap a stud between the post and the carb body. And the one that wont work, epoxy the pieces together
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- Gjason89
29 Oct 2015 05:58
I think I want to find a new carb to work with if anyone has a pair that can spare me with or sell me for a good price
29 Oct 2015 06:01Gjason89 wrote: Ok I will post pics today when I am with the carb just to make sure we are talking about the same thing but I might of explained wrong when I say needle I don't mean the ones for the gas I mean the little I guess shaft that holds the float in place to let it go up and down as the gas goes up and down well we're the shaft hold In place on both feet that are part of the carb they have wholes and hold the shaft in place one has broken off
I was afraid you'd say that. Look for some used carbs on eBay. Take the good parts from the two and make a good set.
- floivanus
29 Oct 2015 06:13 - 29 Oct 2015 06:15
That's usually the answer most go with, BUT the welding only runs about $20 plus shipping if I remember correctly, so that actually is NOT a bad choice when you look at a set of carbs running $80+ on eBay
forums.sohc4.net/index.php?topic=18649.0
Link to carb repair
Link to carb repair
Andrew
Andrew
Last edit: 29 Oct 2015 06:15 by floivanus.
- Gjason89
29 Oct 2015 06:15
I would be willing to do the fix but don't really understand how to do it it would be better cheaper to it but just not sure of how to do the fix and that is if I can find the piece
29 Oct 2015 06:39
If you don't have the piece it's a done deal. Pics PLS. Just to be sure we are all on the same page.
- missionkz
29 Oct 2015 07:25
I'm pretty sure he is talking about the cast alloy boss the hinge pin slides through...
I don't know what fuel will do to generic epoxy but there is such a thing as hot fuel proof epoxy.
It could be repairable if the broken piece still exists.
Welding seems extreme....
I think I'd be scouring eBay for a while before repair it.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
