1976 vm24 on a 1982 ltd 750 engine, carb tuning
- tylerstedham
18 Oct 2015 04:28 #695025
by tylerstedham
1976 vm24 on a 1982 ltd 750 engine, carb tuning was created by tylerstedham
So, i just baught my first kz:) its a 1976 kz 650 b2 fitted with a 1982 ltd 750 engine. Its tuff to find carb tunning advise when the cards are miss matched to the non original engine. I have installed pods on the vm24m the exhaust is some form of 2to1 and 2to1. Any suggestiuons on base carb set ups for this configuration would be a great help, ie main jet size, needle position exct.....
- Thank you received: 2829
18 Oct 2015 04:44 #695028
by 650ed
Replied by 650ed on topic 1976 vm24 on a 1982 ltd 750 engine, carb tuning
There's no such animal as a 1976 KZ650-B2. Ed
- Thank you received: 1656
18 Oct 2015 05:01 - 18 Oct 2015 05:01 #695032
by martin_csr
Replied by martin_csr on topic 1976 vm24 on a 1982 ltd 750 engine, carb tuning
The 650-B2 should be a 78 model. If the exhaust is an aftermarket system, then it probably flows more air than the stock mufflers. Probably a good reference point would be to check into the carburetor tuning of a 650 w 4-1 exhaust & pod filters -- a typical setup is #115 main jets, #17.5 pilot jets, & the jet needles clipped 1 groove from stock. With the 750-4 engine you'd probably need larger main jets at the least.
I know of only one guy who installed VM24 carburetors on a 750-4 engine, but he didn't provide any jetting info.
Last edit: 18 Oct 2015 05:01 by martin_csr.
The following user(s) said Thank You: KZB2 650
- KZB2 650
- Thank you received: 265
18 Oct 2015 05:04 #695033
by KZB2 650
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Replied by KZB2 650 on topic 1976 vm24 on a 1982 ltd 750 engine, carb tuning
I'm running a 17.5 pilot....... nettle in the 5th clip (4th is stock) and 117.5 mains (I need to do some plug chops and may go a 115 but would rather be a little rich than too lean)...... Thinking that should be pretty close to what you have and thinking its probably a 77 or 78 model like Ed says. If it says manufactured in late 76 on the frame its a 77.
1978 KZ650 b-2
- tylerstedham
18 Oct 2015 05:55 #695043
by tylerstedham
Replied by tylerstedham on topic 1976 vm24 on a 1982 ltd 750 engine, carb tuning
Frame says its a 1976 kz 650 ill post a pic asap
- tylerstedham
18 Oct 2015 06:07 #695046
by tylerstedham
Heres some pics of the bike, 1977 kz 650 b1, ? with 1982 ltd 750 engine, i think! Just baught it
18 Oct 2015 07:49 #695055
by 650ed
Yes; it's a 1977 KZ650-B1. Just like cars, bikes are made beginning a few months before the model year. Ed
18 Oct 2015 09:17 - 18 Oct 2015 09:19 #695063
by martin_csr
Using cyclechaos.com the engine is probably from a 1980 KZ750-H1 Ltd, but it has the engine covers from the 650B.
The 750-4 had electronic ignition & 3-phase charging system. I don't know what charging system the B1 had.
If the bike has points ignition, it's probably from the B1 engine, but that's just a guess.
There's no telling what advancer it has, but on the 750 the last 4 digits of the part number are usually clearly indicated on the advancer.
Last edit: 18 Oct 2015 09:19 by martin_csr.
