Noob
  • calegg
  • calegg's Avatar Topic Author
Noob
14 Oct 2015 08:04
#694528
Hey all, i just bought my first motorcycle a few days ago. 1981 Kz750 ltd. I was on here a few days ago looking through things and there was a topic that showed the removal of the air hoses on top of the carbs among other things and I've searched and searched and cant find it again. The reason i ask is that carbs 1-3 are capped and 4 has the hose hooked to it and I don't believe that is correct. I also have the sync gauges but they didnt come with any hoses and wondered what size i need to hook it up as i was told the carbs are out of sync.
I appreciate all the help i can get. moving blindly forward through this site and youtube lol
'81 kz750 LTD - first bike, first project.
  • jackleberry
  • jackleberry's Avatar
Re: Noob
14 Oct 2015 08:44 - 14 Oct 2015 08:46
#694529
Try searching for "clean air system".
You probably need 5-6mm hoses.
And I might as well be the first to say it: The most important tool for your bike is the correct factory service manual which will tell you 90% of everything you need to know about it instantly. (EDIT: like the fact that syncing the carbs is the last thing you do after tuning everything else)
1997 KZ1000P (P16)
2001 KZ1000P (P20)
Last edit: 14 Oct 2015 08:46 by jackleberry.
  • calegg
Re: Noob
14 Oct 2015 08:50
#694533
found it thank you
the manual "the bible" that is listed throughout here is that a good manual to follow
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Noob
14 Oct 2015 11:33
#694554
Welcome. Get a manual and we will help you decipher it. :lol:
  • GPzMOD750
  • GPzMOD750's Avatar
Re: Noob
15 Oct 2015 02:54 - 15 Oct 2015 03:46
#694628
It sounds like you don't have the Clean Air system on there now but I think this is what you are looking for; kzrider.com/forum/2-engine/599546-clean-air-system-delete
It doesn't really matter what carb the petcock is hooked up to but it is usually #2.
Last edit: 15 Oct 2015 03:46 by GPzMOD750.
