Stripping carbs, weird residue
- ydb1
03 Oct 2015 16:36 - 03 Oct 2015 16:37
I stripped my TK-22 carbs so that I could repaint them. All the carbs but one came out clean. I used a gallon of carb dip cleaner and let them sit in there for a few days.
The one carb has a dull, gray metallic residue that comes of on a cloth or your finger if you rub it. I've tried a degreaser, elbow grease and spray carb cleaner but I can't get it as clean as the other carbs.
Any suggestions?
Any suggestions?
Attachment ImageUploadedByTapatalk1443923505.905515.jpg not found
'81 GPz550
past rides:
93 GSX1100G
01 ZRX1200
84 GS1150E
80 KZ550
past rides:
93 GSX1100G
01 ZRX1200
84 GS1150E
80 KZ550
Last edit: 03 Oct 2015 16:37 by ydb1.
- loudhvx
Re: Stripping carbs, weird residue
03 Oct 2015 17:37
Maybe soda blasting. Harbor Freight has a kit.
Make sure to seal off any small openings, especially inside the air horn, and in the main port.
I can't recall if carbs #1 and #2 can be swapped, but if they can, maybe try to put that carb as #2, ( make sure the choke rod still turns smoothly).
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
The following user(s) said Thank You: ydb1
04 Oct 2015 04:45
The discoloration occurs when you leave the carb in the dip too long. It also occurs if you boil the carbs in lemon juice or similar.
Agree with the soda blasting technique. They will look so nice and shiny you will be hesitant to paint them afterwards.
- ThatGPzGuy
04 Oct 2015 05:04Nessism wrote: The discoloration occurs when you leave the carb in the dip too long.
Yep. I only use carb dip for an hour or so on aluminum. It eats it if left too long. I ruined an H1 petcock once when I forgot and left it in for a week. It looked like it was melting...
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- ydb1
04 Oct 2015 08:50
Thanks guys
'81 GPz550
past rides:
93 GSX1100G
01 ZRX1200
84 GS1150E
80 KZ550
past rides:
93 GSX1100G
01 ZRX1200
84 GS1150E
80 KZ550
04 Oct 2015 16:00ThatGPzGuy wrote:Nessism wrote: The discoloration occurs when you leave the carb in the dip too long.
Just a little FYI: most carb bodies are zinc.
- Hollywoodmx
Re: Re:Stripping carbs, weird residue
09 Oct 2015 06:39
Same thing happened to me. It was as said, leaving the carb in too long. I actually think the carbs are coated with something and it eats that off.
Soda blasting was the trick although that coating will be gone for good.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- ydb1
09 Oct 2015 07:44
Did you repaint your carbs? I'm looking at Gun-Kote or Aluma-Hyde for my carbs and calipers.
'81 GPz550
past rides:
93 GSX1100G
01 ZRX1200
84 GS1150E
80 KZ550
past rides:
93 GSX1100G
01 ZRX1200
84 GS1150E
80 KZ550
- Hollywoodmx
Re: Re:Re:Stripping carbs, weird residue
10 Oct 2015 18:33 - 10 Oct 2015 18:34I just soda blasted them to get them even coloured.ydb1 wrote: Did you repaint your carbs? I'm looking at Gun-Kote or Aluma-Hyde for my carbs and calipers.
In Canada I don't have access to aluma Hyde but it sounds really good when I read about it. I like when stuff looks fresh. But I have seen a lot of false claims on aerosol paints.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 10 Oct 2015 18:34 by Hollywoodmx.
