- Thank you received: 659
Carbtune synchronizer
- daveo
1982 KZ1100-A2
- KZB2 650
- Thank you received: 265
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- daveo
KZB2 650 wrote: No fluid to leak or to evaporate and no bubbles........
What about accuracy and ease of use, among other things?
1982 KZ1100-A2
- Tyler
- Thank you received: 92
The carb tune is not a manometer type, it has 4 independent vacuum gauges, they are a slide type and easy to read. It is a nice tool to have but you can of coarse do the same job with yard stick and some tubing from the hardware store for a lot less money. With the carbtune you can use it as a generic vacuum gauge for automotive work if you need it.
"74 Yamaha DT 400 Enduro
- KZB2 650
Dead accurate from what I've read and should stay that way for many years...... piece of cake to use too.
1978 KZ650 b-2
- Thank you received: 2829
www.kzrider.com/forum/3-carburetor/59960...rb-synch-tool#689249
- daveo
Ok, but I should be able to get the same result with the Motion Pro, if properly setup/calibrated...correct?
1982 KZ1100-A2
- jackleberry
- Thank you received: 56
Once or twice.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
- DivideOverflow
- Thank you received: 1
No worries about pulling too much vaccuum and sucking in fluid, just put in a reducer if you are pulling too much.
I havent tried the other product you mentioned.
1980 KZ750E1
North Carolina Crew
- Zephyrrider
- Thank you received: 50
Mick
1994 ZR750 Zephyr C4.
- daveo
Ok, ok...bought one! :whistle:
1982 KZ1100-A2
- RonKZ650
- Thank you received: 240
