Carbtune synchronizer
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
28 Sep 2015 05:38
#692282
How is the Carbtune Pro system different/better than the Motion Pro Sync Pro? :unsure:
1982 KZ1100-A2
  • KZB2 650
  • KZB2 650's Avatar
Re: Carbtune synchronizer
28 Sep 2015 05:52
#692284
No fluid to leak or to evaporate and no bubbles........
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • daveo
  • Premium Member
  • Premium Member
28 Sep 2015 05:58
#692286
KZB2 650 wrote: No fluid to leak or to evaporate and no bubbles........
What about accuracy and ease of use, among other things?
1982 KZ1100-A2
  • Tyler
  • Tyler's Avatar
28 Sep 2015 06:02
#692287
I have a Morgan carbtune and its a very nice tool. With the current exchange rates the price is not much more than the motion pro tool.
The carb tune is not a manometer type, it has 4 independent vacuum gauges, they are a slide type and easy to read. It is a nice tool to have but you can of coarse do the same job with yard stick and some tubing from the hardware store for a lot less money. With the carbtune you can use it as a generic vacuum gauge for automotive work if you need it.
"74 Yamaha DT 400 Enduro
  • KZB2 650
  • KZB2 650's Avatar
28 Sep 2015 06:10
#692288
Dead accurate from what I've read and should stay that way for many years...... piece of cake to use too. ;)
1978 KZ650 b-2
28 Sep 2015 06:14
#692290
Here's a report on the Motion-Pro tool......
www.kzrider.com/forum/3-carburetor/59960...rb-synch-tool#689249
  • daveo
  • Premium Member
  • Premium Member
28 Sep 2015 06:22
#692291
Ok, but I should be able to get the same result with the Motion Pro, if properly setup/calibrated...correct?
1982 KZ1100-A2
  • jackleberry
  • jackleberry's Avatar
28 Sep 2015 07:18
#692303
Once or twice.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
The following user(s) said Thank You: KZB2 650
  • DivideOverflow
  • DivideOverflow's Avatar
28 Sep 2015 09:32
#692317
I have the Carbtune tool and it works great! Very easy to use and set up, no guess work.
No worries about pulling too much vaccuum and sucking in fluid, just put in a reducer if you are pulling too much.
I havent tried the other product you mentioned.
1980 KZ750E1
North Carolina Crew
  • Zephyrrider
  • Zephyrrider's Avatar
28 Sep 2015 13:29 - 28 Sep 2015 13:30
#692357
The Carbtune is one of the best things i have ever bought. Easy as hell to use and very quick - i can check , and if needed , adjust carbs with fuel in bowls in 5 minutes - extremely happy with them - used to have the old round gauge needle jobs - they are a pain in the ass to use in comparison. Cost me about $180 for Pro II model about 5 years ago ;)
Mick
1994 ZR750 Zephyr C4.
Last edit: 28 Sep 2015 13:30 by Zephyrrider.
  • daveo
  • Premium Member
  • Premium Member
28 Sep 2015 15:04
#692382
Ok, ok...bought one! :whistle:
1982 KZ1100-A2
  • RonKZ650
  • RonKZ650's Avatar
28 Sep 2015 16:28
#692401
The Morgan works great and requires no setup. Just hook up the 4 hoses and you are set. As to the Motion Pro tool. :sick: :sick:
